need better tires any thoughts????
Car: 87z28
Engine: 70 LT1
Transmission: 350 TURBO BUILT BY B&M
Axle/Gears: 12 BOLT POSI
![driving](https://www.thirdgen.org/forums/images/smilies/driving.gif)
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
Re: need better tires any thoughts????
Looking for cheap tires or not?
Pep boys has futura super sports that go up to 295/50/r15, or u can try the kuhmo's 275/60/r15(not sure of the height I think they are 60's) The 295's will fit but if u bottom out bad in your area where u live or shocks and struts arent up to par then u may wanna go with something alot smaller like the factory 235's. Because the 295's just barely clear and u may chance taking out some chunks, or u can cut the lip of the fender well. so they tuck under better.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
at one point. I was really concerned about maneuverability
issues.. hence, why I drive a F-body to begin with..I like
they was the car performs under duress..
I had gotten a great deal on some Bridgestone
Fuzion Z-rated, P245/R16's on my Trans am now.
..I had some GTA rims, and cleaned 'em up
I am overly impressed given all four tires were
obtained and mounted for under $400.00.
I think under $400 for tires on our cars is
very cheap.. If I had more dough.. I would
have easily shelled out another $200 bucks
for some serious rubber.
Good luck, go hunt around
I had 295's @ once but they chopped. The roads here are suck a//, but they fit in the rear and only the rear, the fronts were 235's. I am gonna look for a pic and if i find one ill post it!
Street Lethal
04-30-2019 12:14 PM
CarGuyDennis
137
12-06-2016 11:02 PM
