Size of fuel pressure test valve (schrader valve)?
I need to know the exact size of this and if it's male or female? I've heard it's a 1/4" male. but I bought a female 1/4" brass fitting at Lowes and it does not fit. The test valve seems smaller than 1/4".
thanks
'92 Formula
305 TPI
Mods: SLP catback,SLP air foil,ported plenum,Crane AFPR (49psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch...SLP 1 5/8ths are coming...oh yes
thanks
'92 Formula
305 TPI
It is not standard pipe thread. The fitting you bought is most likely NPT (national pipe thread) but the schrader valve is actually a special tubing thread. Pipe threads are tapered, the schrader threads are not. I am not sure what the actual size is, but it is the same as R-12 freon connections on your air conditioner. I used a small piece of a/c charge line to make my fuel pressure guage. Not sure what your doing, but that is what I did. If you want to buy a realativly inexpensive guage, Autozone carries a couple of different ones. Check the application on the instructions, there are 2 different schrader valve sizes.
'89 GTA, Ported Plenum, BBK throttle body, 24lb Motorsport injectors, Jet stage 2 chip, AFPR, no cats and a Flowmaster.
'95 GMC soon to be 383 daily driver w/Howell multi-point injection conversion
Hey guys you're right thanks for the help. I went to Pep Boys and bought the air conditioning hose that handles up to 500psi without birsting. Then I got heat wrap hose to wrap around it for safety.
Thanks guys!
'92 Formula
305 TPI
Thanks guys!
'92 Formula
305 TPI
R3500
08-17-2015 12:16 PM
92camaroJoe
08-13-2015 06:07 AM
