stock injectors? 87 GTA
I found that 1 of my injectors are dead and 1 is intermittent last night, I want to replace them all but have no idea what size they are. I do not want oem again because the injectors are known for having shorts and just problematic.
What size are the stockers? What would be a good brand / size to swap them too? I am looking to pass smog too..
My motor is stock.
Thanks all
My motor is stock.
Thanks all
1 Post
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Re: stock injectors? 87 GTA
only if you can change the injector constant in the prom . You may get away with it ...but why not do it right
Ok, thanks for all the info.. I am not gonna mod the ecm anytime soon, so I will just get a new bosch set. I thought the 24lbs were a bit much with no mods.
Thanks!
Thanks!
