What size injectors do i need 89 350 IROC?
I'm trying to figure out what the stock injectors psi was for 1989 350 IROC ? It's a stock engine,tying squezze more hp. What would larger injectors 24-26lbs and hypertech thermomaster chip do for my 350 ?
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Re: What size injectors do i need 89 350 IROC?
you're not gonna be gaining hp from just swapping injectors. Sometimes, injectors that are too big will hurt performance. ...and hypertech = trash
hp is gained by letting more air into the combustion chamber.. simple as that.
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
Stock PSI= 22#s. No need to change injectors until you start making mods to your engine (major mods not free mods). Even then you can get by with stock injectors and and an adjustable fuel regulator, so long as your injector duty cycle doesn't get much over 85%.
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I did all the mods in my sig....the last thing I put in were the 24# LT1 injectors.
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
The factory flow for our 350s is 22 #/hr... These injectors are run at the factory fuel pressure of 43.5 psi. I see above some confusion between flow rate and fuel pressure.
The best replacement for GMs 22 #/hr injectors are the Ford Racing 24 #/hr injectors. Stay away from the Accel injectors, too many horror stories on this board on that injector.
FWIW: I have been running my Ford injectors for 10 years now.
Yeah, you're right, didn't mean to put 'PSI' in front of 22#s . I am also running Ford 24#s with my 383 at 41 PSI. Sorry about the confusion in the reply.
toronto formula
11-10-2015 06:17 AM
NinjaNife
08-23-2015 11:49 AM
mustangman65_79
08-11-2015 03:17 PM
knight72
08-10-2015 09:32 PM
