L98 Corvette Heads on L98 Firebird
Car: 1989 Firebird Formula
Engine: L98 350
Transmission: 700R
This might be a stupid question. I have heard of people taking the aluminum heads of a L98 Corvette and putting them on a firebird. I have never seen it done or really know of anyone doing it. I just wanted to know if anyone has done it or heard of it. If you have is it worth the time or is it better to do something else.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: L98 Corvette Heads on L98 Firebird
quite a few people do it. I am putting on a set sometime soon on my 305 when the weather is warmer since there is no space in my garage for the car.
I am doing it to lighten up the car.
Car: 90 RS
Engine: 5.0 TBI
Transmission: Slushbox
i did many back in the early 90s,it is worth the effort however you should have them ported,bowl work etc.these heads have GREAT POTENTIAL look at what lingenfelter has done with them add a small cam with some good lift about 520-560 on a 112 you will like it,of course do the complimenting mods
Engine: L98 350
Transmission: 700R
What are the differences in the heads besides the material they are made of?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Please search. I have posted the info on putting L98 Corvette heads on an F-body, based on my personal experiences, many times. There are three big things you need to watch out for: No EGR passages, the intake bolt holes are the older style, and they're missing one of the accessory bolt holes in front.
Car: 1983 G20 Chevy
Transmission: 4L60
Corvette EGR system looks like this:
Click this thread, I posted it here:
https://www.thirdgen.org/forums/tpi/...emissions.html
Engine: L98 350
Transmission: 700R
Thanks I guess I needed to read more.
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
You can buy an EGR kit from Scoggin Dickey. The kit includes a bung to weld to your headers and a tube to connect to your intake manifold.
I recently put different heads on my L98 and the kit worked fine (although it is a bit of trouble to install since the passenger side of a Firebird is so crowded).
Hope this helps.
Hope this helps.
Engine: L98 350
Transmission: 700R
Well I don't have the factory TPI. I have the Holley Stealth Ram now.
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
I'm just wondering WHERE to find aluminum L98 heads, especially the standard port ones, not the raised ports.
Guess I'll have to drive up to Orange County some day and look around.
Try looking in the Classifieds at http://www.corvetteforum.com/ Also, they're the exact same as ZZ3/ZZ4 heads. The ZZ4 heads have better springs, though.
I doubt you'd find any in a junkyard though. I think I have seen one 80's Corvette in 10 years of going to the junkyard. You'll have a check a specialty auto salvage yard, and expect to pay big bucks.
Car: 1983 G20 Chevy
Transmission: 4L60
Engine: L98 350
Transmission: 700R
I looked on ebay an the only ones I can find are a set of new ones for 990.00. Then with a port job it would start really adding up. I think i might just go with a set of aftermarket ones.
Car: 87 GTA
Vortec heads, with the Scoggin-Dickey TPI base, would be a great choice! For that $990 cost, for just their asking price, you could ge6t brand new Vortec heads, a brand new TPI base for them, and make more power, than the L98 aluminum heads could.
ambainb
04-25-2016 10:21 PM
