How fast is a 305 tpi?
Old 05-15-2007, 03:33 AM
  #51
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: How fast is a 305 tpi?
Maybe He's referring to a stock bottom end?
Old 05-15-2007, 07:14 AM
  #52
iroc88lb9's Avatar
Originally Posted by 90 white Z
I thought you said you had the oe camshaft??
I think you just owned yourself
uhhh...yeah i owend myself...your a genious.
i havent ran the 1/4 with the new cam.i put a new cam in,because my harmonic balancer exploded into 2 peices,so,the car JUST got new timing chain/cam and l98 vette heads,car has only had THIS setup for about 2 weeks. every vid i have right now,except my exhaust vid....is 100% stock,including the exhaust.
Originally Posted by MARO-MAN
You must be cutting a darn good 60" time, running NOS, and have a different cam at the very least. I just don't see any other way to make your "stock 305 TPI" run 13.4 in the quarter mile.
best 60 was a 1.9,then followed by a 2.0/2.1 all day once the car got hot.
Old 05-15-2007, 08:48 AM
  #53
MARO-MAN's Avatar
Car: I've had 4 thrid gens!!
Engine: Someday again I will have another!!
Ok, I am sorry but I don't believe you ran a 13.4 with a stock 305 with exhaust mods. Now that you have 113 heads & cam I still wouldn't believe you if you said you ran a 13.4!! There are guys on here with 113 heads, cam, intake work, exhaust, T5, and good traction and they run high 13's...............on nitrious I would believe it!!
Why don't you post exactly what you had done to your 305 at the time you ran a 13.4 in you 305 TPI Camaro??
Old 05-15-2007, 08:57 AM
  #54
iroc88lb9's Avatar
are you guys seriously that thick headed?
i HAVE posted everything thats done. i love the fact that,if TGO guys havent done it...the world has never witnessed it. please...get a damn life.
on nitrous i have no idea what it runs in the 1/4...ive only used it on the streets{was installed after my trip to the track}
Old 05-15-2007, 10:20 AM
  #55
MARO-MAN's Avatar
How old are you that you need to start telling people to get a life.......
Your the one who needs to get a life, becasue you the one on here trying to pass a 305 stock TPI with exhaust work off as a 13 second car.....
Old 05-15-2007, 12:22 PM
  #56
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
one way or another , zeph's formula is a BEAST. that's how a formy should look!
making me want to trade the 92 rs...
Orr89RocZ
04-25-2016 08:28 AM
gta90
09-15-2015 04:00 PM
st.evel07
08-13-2015 06:15 PM
Sanjay
08-12-2015 03:41 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: How fast is a 305 tpi?
