aluminum Vette heads VS vortec?
Car: 88 GTA
Axle/Gears: 3.27 9bolt
I am fixin to start buying parts for my engine. im looking to get around 300hp out of it. Nothing major I just wanna be able to stick right with a Ls1 car.
I am looking at the aluminum TPI vette heads and the Vortec heads.
Can anyone tell me what the differances are? mainly witch one will give me more power.
I will probly eng up running a Lt1 intake.
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Re: aluminum Vette heads VS vortec?
300 hp will not stick with an LS1 with a few mods. It is said an LS1 with full exhaust can run 12's.
However, vortec's will out flow the aluminum TPI heads.
Car: 88 GTA
so i woul dneed atleast 350hp then? maybe a 75shot of N20 for when i need it. haha
So i guess ill be going with the vortecs.
Im sure hti shas been asked before many times but what kinda numbers are people putting down with votecs? and TPI intake.
Car: GTA
Engine: 383 HSR
350 to the wheels can get you 12's, just keep in mind that LS1's tke literally nothing to get low 12's. Throw in a full exhaust, a cam with a tune and you will need to get deeper pockets.
if you want LT1 intake u cant run vortecs.... thats the only downfall of the vortec heads... there is no good intakes for them except for the HSR.
the vortec heads will make more power over the L98 heads, even tho the L98 heads raise compression some. but both are capable of making 350hp in the right combination
Converted LT1 intake and nice cam to match with Aluminum L98 vette heads will easily make around 320-350 hp and run with a LS1 car. you can do that for fairly cheap too.
1 Post
Car: 92 Z28
Engine: Boosted LSX
any vortec carb intake can be converted for what a HSR cost also.
SDP vortec lower intake, AS&M runners
You have a few diff. options. Some cost alot more then a HSR. but Id say theyare worth it to run the vortec heads. Then again the alum l98 heads are alot lighter, will yeald you more compression, etc...
Hard call. I guess it would depend on how much you want to spend..
Car: 88 GTA
well the vortec heads are nice, but i cant see spending over $1000 on intake parts. just to get it to make power above 4500 lol.
I can take the $500 ill be saving by running a Lt1 intake and put toaward heads i guess. this sucks
84z96L31vortec
08-20-2017 12:16 AM
ambainb
04-25-2016 09:21 PM
