MAP sensor
Old 03-28-2007 | 06:38 PM
vetteboy86's Avatar
MAP sensor
Manifold absolute pressure is in PSI, however I want to know how this relates to engine vacuum. Does the map sensor read a pressure change from the standard pressure?
Old 03-28-2007 | 07:34 PM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
Re: MAP sensor
"Manifold absolute pressure sensor - Monitors the pressure of the air in the intake manifold
The amount of air being drawn into the engine is a good indication of how much power it is producing; and the more air that goes into the engine, the lower the manifold pressure, so this reading is used to gauge how much power is being produced. "
howstuffworks.com
Old 03-29-2007 | 06:36 AM
vetteboy86's Avatar
Re: MAP sensor
So can it relate to vacuum?? I saw a web page once that equated the map sensor voltage to vacuum. Who knows if that was accurate or not.
meeklay812
10-01-2015 03:46 PM
HoosierinWA
Members Camaros
09-29-2015 12:43 PM
dusterbd
09-29-2015 08:40 AM
SS-EXPRESS
09-28-2015 09:14 AM
efiguy
09-27-2015 01:30 PM
Quick Reply: MAP sensor
