Problems Idling
Old 03-26-2007 | 11:51 AM
Matt_Critt's Avatar
Car: 1986 Camaro Iroc
Problems Idling
I have a 86 Iroc 305 TPI with a 700r4. Recently the intake was takin off and apart to redrill and tap the thermostat bolt holes, the bolt broke off. I have also just replaced spark plugs and wires and the distributor. The engine will start, but it idles very rough and barely stays running. The timing mark is set to roughly 6 degrees, but jumps around, due to rough idle.
any clues??
Old 03-26-2007 | 12:53 PM
Matt_Critt's Avatar
Re: Problems Idling
do the plug wires need to be routed a certain way to prevent them from arcing against the manifold
Old 03-26-2007 | 01:56 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: Problems Idling
You might want to double check and make sure the spark plug wires are routed correctly. If not it will cause a missfire/bad idle.
Old 03-27-2007 | 07:56 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Re: Problems Idling
sounds liek you have either a split or missing vaccum hose. Same thing happened to me and they were the symptoms ...mushy throttle and had to have my foot on it to keep it idleing
Old 03-27-2007 | 10:44 AM
Matt_Critt's Avatar
Re: Problems Idling
Vaccum is exactly wut it is, got it barely running today and could hear the hiss from a line. sounds like its comming from underneath the plenum. is that where the EGR valve is located?
Old 03-27-2007 | 12:34 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Re: Problems Idling
That's where it is located.
Old 03-27-2007 | 01:18 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Problems Idling
vacuum leak..and you got the firing order correct right?
Old 03-27-2007 | 01:43 PM
Matt_Critt's Avatar
Re: Problems Idling
i did have #5 and #7 plug wires mixed up, and my auto class teacher, where i am working on that car at, says its a vaccum leak, and u can hear the hiss when it runs
Infested
05-22-2018 11:56 PM
db057
08-22-2015 08:17 PM
zeitghaist
08-18-2015 07:33 AM
perZ
08-15-2015 01:17 PM
Quick Reply: Problems Idling
