TPI. TPS bolts
Car: 91 formula
Engine: 350 tuned port. bolt ons
TPI. TPS bolts
does anyone know where they would sell just the 2 bolts for the TPS. my bolts are stripped and the tps is just hanging on.
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
What is the thread size? I have a stripped screw also, and have tried to find a repalcement and could not. These little screws are something like a 4.5mm thread. Sears, Lowes and Home Depot do not carry this funky size.
Car: 91 formula
no supply shop around. I went to ace and home depot they do not have it. maybe i can get on from another car at the junkyard.
Car: 88 Trans Am
Engine: 355 c.i.
Transmission: 5 spd.
Axle/Gears: 3:42s
are you sure the throttle body isn't stripped out instead of the 2 bolts? Any way you might try Ace Hardware or some type of hardware store, most of them have all kinds of screws or bolts in metric sizes, usually in those plastic boxes on a rack.
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
I know you have this solved already, but the 2.8 V6 F-bodies use the same screws on their TPS. Very easy (unfortunately) to find one of those in a junkyard and score the screws from it.
mdtoren
08-16-2015 05:45 PM
