88 t/a 305 tpi backfires fuel BADDDDDD
Car: 88 trans am, and 06 focus DOHC
Engine: 305 tpi
Axle/Gears: 4.56 screaming pave eating :-)
hey all maybe you guys can help or give some advice... my 88 t/a 305 tpi 700r4 tranny 4.56 rear fuel seems to backfire inside the cat and BLAST it out the exhaust only when i decelerate off the gas pedal coming to a stop... any ideas lol im stuck my brain doesnt want to function
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Why are u running the waste of 4:56 gears with a TPI?
Did u swap speedo gears so the VSS reads right?
Leaking 9th injector?
Bad temp sensor?
Leaking injectors or regulator?
later
Jeremy
Bad temp sensor?
later
Jeremy
Engine: 305 tpi
injectors arent leaking either is regulator....all temp sensors read good when i put scan tool on it seems like its getting alot of fuel little air....check engine light is on not sure of codes but i know it has to do with emissions very very wierd
well 4.56 came with car when i bought it
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
not to change the thread but how does youre car perform with those gears? does it hook up?
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
When was the last time you time you gave your car a good tune up?? (With good quality replacement parts)?
Engine: 305 tpi
8t9 runs pretty good with 4.56 very fast off the get go not using for racing just because i bought it this way
tune up no but i have brand new ac delco plugs in it cap and rotor i have yet to put on it due to coldness of the outside LOL cant wait till spring weather then i should have tune up done :-)
but i do think the motor is getting to much fuel and not enough air i hate TPI rubber air intake tubes they are too long lol maybe MAF is screwed up not sure yet
Sanjay
08-12-2015 03:41 PM
