PCMForLess Re-Tune, Help Me...
Old 03-04-2007 | 12:30 AM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
My car was tuned nearly 6 months ago but since then I've installed new RR's, cam, valvetrain, exhaust, etc. Some of the questions from when I first tuned it threw me for a loop, but I want it done 100% accurate this time. You can see a majority of my mods in my sig, but ask any questions to help me out. Thanks.
Here are the things that I'm not 100% sure about and their options on PCMForLee's order sheet... what should I choose?
Real Order Sheet - http://www.pcmforless.com/index.php?...id=2&Itemid=43
Shift Firmness
- Firm As Possible
- Firm Shift Points
- Quicken Shifts
- Leave As Is
Throttle Body Injection
- Yes
- No
MAF Type
- Vehicle Not Originally Equipped
- Stock
- Aftermarket
- (Other Car Specific Options, Like 'vette, impala, etc)
MAF Ported
- Stock
- Ported MAF
- N/A
MAF Descreened
- No/Stock
- Yes
Vehicle Anti Theft VATS
- Leave As Is
- Remove
All Of The Trouble Codes
- All Have Option Of 'Leave As Is' Or 'Remove'
Duration @ .050 (I Have LT4 Hot Cam, LT4 Springs, Stock Lifters, 1.5RR's)
- What's My Intake?
- What's My Exhaust?
Lift(Max Valve)
- What's My Intake?
- My Lobe Seperation Angle Is 112, right?
Head Information including Flow Rate
- I never did know this one, I just said 'Stock L98 Iron Heads' last time..
Displacement CID
- I have L98, but it's bored .40 over... so that's technically what, 357? Just say 355?
Old 03-04-2007 | 03:57 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Shift Firmness
- Firm As Possible
- Firm Shift Points
- Quicken Shifts
- Leave As Is
Answer: You have a 700R4, the computer only controls the lockup from the tranny. Nothing else. Most people set the lockup to 45 mph.
- Yes
- No
Answer: No, you have Tuned Port fuel injection even with the HSR.
MAF Type
- Stock
- Aftermarket
Answer: With a 1991 car, you have Speed Density, no MAF.
MAF Ported
- Stock
- Ported MAF
- N/A
Answer: No MAF
MAF Descreened
- No/Stock
- Yes
Answer: Same as above....No MAF.
- Leave As Is
- Remove
Answer: VATS is something that if your car didn't come with it, you need to delete it or it won't start. Most just delete it anyway.
Answer: If you are not setting anycodes, you are fine but if you are, look them up and get them taken care of.
- What's My Intake?
Answer: LT4 HotCam is a 218/228 .050
Lift(Max Valve)
- What's My Intake?
Answer: Yes, 112 lsa and lift for both using 1.5 RR is .498.
L98 flow numbers:
120/100 @.200
163/129 @.300
189/148 @.400
199/164 @.500
199/167 @.600
Displacement CID
Answer: You have a 357...say 357.[/
Old 03-04-2007 | 06:56 PM
Cam-aro's Avatar
Car: '91 Z28
Awesome, exactly what I was needing. Haha, I have absolutely no clue why I said something about the MAF, duhh... I remember wondering about that the first time I tuned, but just had a brain fart, forgot about the speed density. Thanks for reminding me .
So can PCMForLess tune the lockup? So 45mph sounds like a good range to set the lockup to?
Old 03-04-2007 | 07:21 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Yea, you can tune for the lockup for the tranny. Stock is like 40-42 and most just go to 45 with it.....some do 50....personal perference.
Old 03-06-2007 | 10:35 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
how is the performance with their tunes? im thinking about putting the tpi back on my can and considering a mail order chip or just buy all the burning equipment myself.
Old 03-07-2007 | 06:17 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I've heard great things about them but for $200 or however much it is, you can get the Ostrich for $175(realtime tunable), a wideband, and ALDL stuff for under $350 and tune it yourself. However, some of the numbers I have seen from TPI and LT1 cars are impressive....about 20hp gain for the most part.
Old 03-09-2007 | 10:20 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula, '95 Formula
Engine: LC9 , LT1
Transmission: TKX , 4L60E
Axle/Gears: 3.50 9" , 3.23 10bolt
I'm trying to determine what I want.. For a street/strip car I'm not sure what's ideal.Some say lock right at peak torque RPM, some say lock after xx mph..
Whats your reasons for 45?
-- Joe
Old 03-09-2007 | 12:15 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
-- Joe
My reason for 50 is that its a nice rpm to lockup. I'll be driving in 4th gear and at 49 mph, I am pulling 1600 rpms with 3.73s and 29" tire and its a good rpm in my opinion to lock it up and puts the rpms at 1400 rather than 1000 or 1100 where it used to be. Doesn't seem to struggle.
italiano67
12-11-2016 10:21 AM
F0xBody50
Theoretical and Street Racing
50
01-04-2002 08:46 AM
Ray87Z
03-21-2001 01:33 AM
burnoutrpm
Carburetors
03-01-2001 08:26 PM
mostafa3k
02-06-2001 08:35 PM
