224/236 cam too big for ported TPI?
I have a tpi setup that was ported by Lingenfelter. I want to know if this cam will be too big. specs are 224/236 @ .050 on a 110 LSA,.528/.520 with factory rockers OR .568 .560 with 1.6 rockers. itsa comp cams piece. Was thinking about using it on my ZZ4 HO shortblock with AFR 180's. Also concerned about california emissions. I had and still plan to use an LPE 219, but I am curious about what I can expect with this cam. Thanks
Will
Will
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
You know with that tight of a LSA and that much duration your in for real trouble unless you are a top notch EFI tuner and ready to burn a lot of chips. In order to be able to handle that radical of a cam you need cubic inches to mellow it out. Still 110 LSA, that's brave!
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
check out summit there's a comp cam 212/218 with 110 LSA you could tame that cam eaier and it matches the TPI much better.
check out this thread >https://www.thirdgen.org/forums/tpi/...stock-l98.html <
i made a post with some good cams to chose from in one of the later posts. good info in there about cams if you mind reading.
Car: White KSwisses
Engine: 5.3L Gen III
For example, i had a comp cams xe 224/230 on a 112* LSA. It wasnt too harsh. Unfortunately i sold the car before i was able to dial in the tune, but it was definitely do-able.
But dont make the mistake of thinking you wont have to do any tuning the the LPE 219 cam.
LT1Formula
20
11-14-2015 12:02 AM
Sanjay
08-12-2015 03:41 PM
