Visual TPI intake manifold ports
A friend of mine, Jerrywho (you know him as the guy who made up the siamesed SLP runners) has done it again in the TPI fabrication department. Using three differently-ported Edelbrock intakes, he used special modeling rubber to create a visual look at what a TPI intake is like on the inside.
I know its really difficult to see in pictures, but I'm posting these along with their measurements to give you an idea of where the restriction is in the TPI intake. Its right where the injector bungs are; it really narrows down in that area just before the air enters the head.
I took pictures of all four sides of the rubber. On the left is an extrude-honed Edelbrock intake, the middle is my ported Edelbrock intake, and on the right is Jerry's intake. He welded up the roof by the injector bungs, then CNC'd the port to raise the roof level by .070" of an inch over the extrude-honed intake. You can see the difference in the second and fourth picture. Now I know why I only gained 5 hp at the wheels after porting my L98 heads to the max, and adding 1.65 roller rockers. I just couldnt get any more air thru the narrow part of the intake manifold.
The extrude honed intake measures 1.160" x 1.700" at the narrowest point by the injector bung for an area of 1.972 sq/in.
My intake measures 1.140" x 1.650" at the narrowest point by the injector bung for an area of 1.881 sq/in.
Jerry's modified intake measures 1.230" x 1.930" at the narrowest point by the injector bung for an area of 2.374 sq/in.
Pics here: http://new.photos.yahoo.com/sharkke@...60762390274768
Thanks for the post Kevin. This is one of the efforts going on here in Southern California to improve the flow of the TPI intake system.
The 2nd and 4th pictures show the side view of what Jerry has done. Not only has he greatly improved the cross sectional area of the runner he has dramatically improved the intake angle into the head.
With the modified factory plenum, moded SLP intake runners and what Jerry is doing to the Edebrock intake manifold I believe this system will surpass the Accel Superram. I firmly believe we will be seeing 500hp motors with TPI this year.
As some of you know there is another effort using the First intake manifold with the SLP runners and GM factory plenum. For most I believe what Jerry is doing will be the easiest route to take.
Stay tuned as more information will be comming.
Thanks. One of the coolest posts I've seen in a long time. Would there be any benefit to building up the floor ever so slightly at the exit port of Jerry's manifold to further improve the exit angle? Or will that just decrease the cross sectional area at the tighest point and negate any potential gains.
Mark, you "might" be able to do that somewhat starting out with a stock Edelbrock casting without welding up the floor. I believe the Edelbrock manifold Jerry is using is one that he has modified in the past and the ports may have been enlarged from stock for another project. As I stated above more information will be comming.
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Good post...Ive always known the base to be the restriction on my setup. Even fully ported it still doesnt flow anywhere near what my ported SuperRam does. I love TPI so i want to keep it or i would have swapped it out for a stealthram when they came out.
Ive been thinking about pulling the base and doing something more with it. This post is just lighting the fire for me.
kevin...do you have any flow numbers? Or before and after power numbers yet?
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
Interesting post.. I find it especially interesting because my whole TPI intake (baseplate and all) is lying on my bench right now
I'm not quite sure what the blue things are... Are these molds of the criss cross passages inside the intake manifold? Or do they have something to do with the runners?
One thought about the narrowing near the injectors.. Could this not have been on purpose? A narrowing would increase the air velocity which (might) help with atomization etc.. (Just guessing of course).
The blue things are molds taken of the inside of the runners. That way you can see the exact shape and measure exactly the size of the runner.
The Edelbrock TPI manifold had to cover both the 305 and 350 motors. Like the factory unit there is a compromise. The injectors are positioned to squirt into the head intake runner. You do not want the intake manifold runners to have a smaller cross sectional area than what is in the heads.
Car: 90 IROC
Engine: 406
Most of the TPI stuff was about velocity. But when you really start making good power. Those velocity points now become known as restrictions.
I would like to see pics of the outside of the base that jerry is working on as well. To get a better idea how this was done. Looks promising from the base runner plugs you guys posted.
Car: 1991 Z28
Engine: 350 TPI RAMJET COMING
That's cool. I'm watching this thread with great intrest. If you get a chance I would like to see a picture of the welded manifold.
Car: 90 IROC
Engine: 406
My question is why didnt Accel, edlbrock, lingenfelter. who ever it was that revamped this thing, from the stock TPI base, didnt do something similar? You think they could have gotten it to flow more like 275/300 cfm.
When those companies designed the intake back in the 80's, they didnt have the knowledge that we have now. Look at all the replacement street intakes that Edelbrock has. They're only slightly better than stock. They put all the good R&D into the race intakes.
Car: 1991 Z28
Car: 90 IROC
Engine: 406
Is there a certain number your looking for as far as flow goes from this intake? What heads are you running that flow over 300?
I know you want the intake to flow more then the heads if possible. So as not to be a restriction. I think a stock Accel/Edelbrock base is right around 250 cfm. Extrude honed 275 maybe?
I would be happy if i could get around 300 cfm out of my base. Dont know if that will happen. My SuperRam runners are ported out about as far as the castings will go. Stock they are around 280/290. so runners must be over 300cfm now. If i could get that out of the base as well. when bolted together it would drop im sure. Your RPMS and victor jrs are flowing in the 280 range. Would be nice to get that out of a complete TPI setup.
I also have heads flowing over 300 cfm at cam lift and hope to have some data with my hogged out FIRST flowed on the heads - since the local shop has no provision to flow the intake alone. I have an untouched FIRST base and will test a stock TPI base and fully ported GM TPI when I finally get some time to flow everything. I'll include the on head flow numbers,, along with the flow including the runners and plenum while I'm at it. I saved flow numbers posted a couple years ago when someone else flowed a stock TPI, SuperRam, and MiniRam on a set of heads flowing in the 250 cfm range and it was very interesting.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
It will be here tomorrow.
1 Post
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
What intake gaskets are you guys using with the edelbrock manifold ?I have 200 cc ports with heat cross over and cant find any with large enough ports and heat cross over for egr .Thanks
280 cfm at .600 lift is nothing to sneeze at especially with a 1205 opening!!
Still planning to have them welded. There is one guy in the area that is semi-confident that he won't warp them,,, but Ken at FIRST injections said if they did warp he could cut and reweld them in the jig for me. So,,, as soon as he can get to them,,, it's a done deal.
Wish I lived around you guys,,, I'd love to throw this ported FIRST in the mix,,, but I'm sure Jerry has his hands full,, although I'd pay for my part of the bench time!!!
Kevin (KG)
BadSS I would love to see your intake in the mix. As you saw in the picture Jerry has my as cast First Intake for the test. Maybe you can ship yours out here and I can get with Jerry and get it flowed using his fixture.
This would most likely be a stand alone test as the others would be completed but I would be willing to pay for the shipping back to you and pay for the test. Then we could include the results with the rest of the data as they would be flowed on the same bench.
Then the only test missing would be a fully ported Vortec TPI manifold. However it may turn out to be the same as the Edelbrock TPI. Especially if the unmodified versions flowed about the same.
Jerry
Car: 1991 Z28
a. post bump b. I measured my stock port 062 (1998 Tahoe) casting vortecs: 2.175 x 1.185......makes you wonder. That is really raised runner. That's 2.578 LOL no wonder Vortec heads work..........
Jerry
I just got back to work from West tec and it was a great learning experience on Tpi base air flow. The cool thing was seeing a Tpi base flow 300+ cfm. when I get home from work I will e-mail the flow numbers to each of base owners and see if each base owner Will let me post the numbers.
Jerry
One side note we started with flowing the fixture to mount the base and with a 3/8s radius on it we got 430 cfm so you know the adapter will not be a limiting factor on our base testing program.
Jerry
Jerry
Car: 90 IROC
Engine: 406
Jerry
Jerry
Jerry if you dont mind would you share photos of your base? IM wondering how you went about opening the area around the injector holes.
#42
My ported base was 290 cfm @ 28" and I think that good for a first prototype port. I think 300 to 310 can be a reality
Jerry
#43
290cfm for an Edelbrock intake is unheard of. That is very good. With a little more grinding in the right spots I know you can get above the 300cfm range.
Jerry emailed me the results of my First intake manifold but he is going to double check it next week to be absolutely sure. So I will wait until then to post the results. Things tend to get out of hand on the internet.
#44
Car: Faster
Engine: Than
Transmission: You!
CFM at the expense of velocity? Sometimes bigger isn't always better, not saying that this is the case here though. I'd like to see some before and after dyno results if possible.
#45
Jerry
#47
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
Jerry,
Are you going to use an engine dyno or are you going to dyno the engine after it is installed to get the RWHP?
....All this talk has me browsing through the autotrader looking for a good project car......
#48
Hehehehe. That is good to hear James. I would love to see you back in the fray. With the new AFR Eliminator heads, new design cams and other new products on the market I think someone will go by me. I know if I had to do it over again I would change a couple of things.
#49
Engine: 3.6L
Looking at what you have achived as far as power output I think your choices have been proven right so far. The new AFR heads look good and come with a warranty that you won't have if you buy a new set of TFS heads and then send them to the head porter only to discover issues with the heads. I'm not to keen on custom one-off mods but that is necessary when trying to extract every last HP. My thoughts are either the dyno was wrong or it will take vincent and all the other 350-383 CID TPI-based 3rd gens in our area a couple years to catch up to you. I have no doubt you can run sub 12-second times if you can hook the tires. Vincent won't race you if he knows you will win, and you will, so he won't be racing you anytime soon.
#50
Jerry
