lt4 hotcam with 1.65 rockers
I installed a lt4 hotcam & had my stock heads redone with larger springs to handle 1.6 rocker arms. I am just getting around to installing the rockers & i noticed they are 1.65 rockers - will i be ok. Does anyone else run 1.65's? Will that extra ift hurt or help me horse power wise?
you may also need to check pushrod clearance, where the pushrod goes through the cylinder head by the intake ports. check for binding. with the 1.65 ratio, the pushrod might move through a greater range for movement.
New2Chevy
09-28-2015 12:35 AM
TX-SleeperC5
09-24-2015 03:13 PM
