Late 92 (corvette leftover) runners
Car: 92 Z28
Engine: 350tpi
I've got a late 92z. It's got the black "leftover" corvette valve covers and the corvette TPI runners. Do these flow better then stock camaro runners? Also, what other leftovers did the late 92 Z's get from the vettes?
Phyte
Phyte
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
You are correct, they came with black valve covers, but they are not from the corvette. The corvette had special magneseum ones. They also got the corvette left over runners as they are a differant shade in color and material I believe (but they flow identical) and you also started to the get the TPI TB plate delete. Its plain. Does not say anything on it. The plate is accually from the newer LT1 motors that year.
Royal_Z
09-30-2015 08:45 PM
