stock air intake restrictors
someone told my son on his 1986 Z28, if you cut out the tube restrictors on the air intake on his car, he would see an improvement. It's the plastic piece molded into the air intake, under both the driver and passenger air breathers....any input, if so, just cut it out???
thanks in advance!
thanks in advance!
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Your not talking about those deflectors on the bottom of the airbox are you? Those are for repelling water to keep them from getting soaked. I modded my airbox already and cut the bottom almost completly out, but I am doing a ram-air setup at the foglights. I drove it around like that (haven't setup the ram-air) and didn't notice any improvment. Just made a loud hissing sound from the front (it was kinda cool).
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Removing restrictions is a good thing, but won't do much good if it's sucking hot engine bay air.
Got a pic?
Got a pic?
Car: 1990 IROC-Z
Transmission: 5 Speed
I cut the plastic things out from under the airbox, I didn't notice a huge improvement, but its better than before. As for water, I drove through the rain not long after doing it, and I pulled the air lid and checked the filters afterwards and they had no water whatsoever on them. My 2 cents.
Car: 88' IROCZ
Axle/Gears: 2.77
thanks in advance!
thanks in advance!
The 406 isn't in this Camaro is it?
The bottom baffles of the stock air box are meant to keep stuff like leaves from blocking air flow into the filters.
As long you don't change the filter elevation rain/splash water isn't a problem if you cut the baffles off.
1992 Trans Am
05-10-2023 07:19 PM
