TPI Swap now no start????
1 Post
Car: 86 Jeep CJ-7
Transmission: Turbo 350
Axle/Gears: Dana 44 3.73
hello everyone new to your board well to start off ive got a 350 that ive just swapped a TPI off a 91 well i just tried to start it and i get nothing if i spray starting fluid in it fires up and runs as long as i keep feeding it so the injectors arent doing the job what would cause this?? also it has the vats removed from the chip so its not that thanks for any help you guys can give me.
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
If you have VATS removed then it might be a fuel problem. How is your pump wired? I have dealt with a lot of TPI wiring, maybe I can help you.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I dont like to mess with electronics when i have seriouse issues, i trashed the TBI, but the TPI is worth saving for low end torque, but my carb will deliver top end power.
1 Post
Car: 86 Jeep CJ-7
its in a daily driver jeep doesn't really see alot of high rpm's
Car: 1990 Formula
Engine: 95 LT1
Sounds like VATS or a relay problem. Test for power at the relay. Test your injectors and make sure they are pulsing. I have use a painless harness before and it was very easy. How do you have the injector circuits and the fuel pump relay powed?
1 Post
Car: 86 Jeep CJ-7
well it was really like a 3 wire hook up on this harness, it had a fuse block and the 3 wires by it 1 for batt+, the other for acc+, and the last is for the fuel pump +. as for vats I got a chip from painless that disables vats
how would i test the injectors pulse and thanks so far for all your responses. also is there anyway to test the magnetic pickup of a dist?
Car: 1990 Formula
Engine: 95 LT1
A device called a noid light. It plugs into an injector plug and flashes as the injector pulses. What kind of distributor are you running? The distributor sends the pulses for the injectors.
1 Post
Car: 86 Jeep CJ-7
its the small cap hei the uses the 2 smaller plugs on the module like a 2 pin and 5 pin to plug the harness into. Ill have to pick up that light tomorrow hopefully a part store is open. And thanks for your help so far
Car: 1990 Formula
Engine: 95 LT1
1. Check for injector pulse, 2. Verify the pump and relay are working, 3. Make sure all connections are good.
Car: 1990 Formula
Engine: 95 LT1
Things that will cause no injector pulse 1. VATS, 2. bad ignition module, 3. wiring problem, 4. ECM problem. What does the chip from painless look like? I had to fix someones swap because the instructions with a painless VATS bypass module was wrong.
1 Post
Car: 86 Jeep CJ-7
it was a new chip that goes in the ecm, just installed a new ignition module all i can think of is a bad pickup or a bad ecm since im not sure if it was good. And thanks again bingo
1 Post
Car: 86 Jeep CJ-7
Ok Problem fixed, After a few hours of trying differnt things and tracing wires comparing to schematic It turned out being the adapter I had to go from the big 4 plug to the small 4 plug for the control module the wires were put in backwards made a new one plugged it in and fired right up!!!!.
Thanks again Bingo for all your help
Here's a pic of the plug i was talking about
Sanjay
08-12-2015 03:41 PM
