Eliminating 9th injector
Car: 88 GTA
I am gonna do a TPI swap on my 84 Chevy pickup, and scored an early 305 setup from an 85 engine, which is nice since it will bolt to my old style heads. I already have 22lb injectors for my 350, and will be using an aftermarket (eficonnection) harness for SD. Since the early TPI has the cold start injector, which shouldn't run with the SD harness or 730 ecm, can I just leave it there unplugged or would it be better to get a fuel rail and runners from a SD car? Thanks for any info.
Terry
Terry
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Terry
Terry
I used a TPI set-up from a 1988 Trans Am..
Because my original one was beat up.
Just make sure you replace the O-ring if
damaged, so you dont have any leaks..
and also, make sure the 9th injector is
seated true in its intake housing. Torque
it down and leave it unplugged, since you
dont have a 9th Injector harness
Ive had no problems or leaks running a 1988
9th injector cold start TPI on a 1989 L98 car,
Not sure about a 1985 set-up tho.
Sweet Deal,
I can hardly see the 9th start injector there anyway, But
for peace of mind and visual.. I will look into the block off
plate this comming spring.
Thanks for the suggestion
Car: 1988 Pontiac Firebird Formula
Engine: 5.7L 350 TPI .030 over 10/1 Comp.
Transmission: 700R4 Street Rod Package
Axle/Gears: 7.75 Borg Warner 9 Bolt 3.73 Gears
Can you tell me the name of the companys which offer this cold start infector block off kit?
Thanks,
Bobby
Thanks,
Bobby
