question on "is this correct"
Old 11-17-2006 | 01:09 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I'm looking at getting a v8 convertible and I'm looking at some pictures of a 91RS with TPI injection. Alot of work has been done under the hood of this car as I see headers, some wiring hacked n moved , aftermarket ignition. But I'm also seeing center bolt valve covers. I thought center bolt heads n valve covers didnt happen until the LT1 series??
This is making me wonder if the heads only were swapped, or if the whole engine has been swapped. Or I'm in the wrong. The person selling didnt do this work and only bought it, got it running, and is now selling it. He has no clue what all has happened with the car.
Old 11-17-2006 | 01:26 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Centerbolt valve covers started in 87 I believe. I know my 86 had perimiter and my 87 has center.
Old 11-17-2006 | 01:43 PM
Dale's Avatar
Engine: 350 S-TPI
ok, so I'm wrong. Thanks.
91 RS with TPI will be a 305 with 210hp/285tq correct?
Old 11-17-2006 | 03:21 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
No RS convertible were built with TPI.
Although it was possible to order on a RS convertible in 91(maybe 92 ),
What you have is a formerly v-6 or TBI v8 RS convertible that someone has put a TPI setup into or on.
The VIN will give it away, 8th digit is engine code.
later
Jeremy
Old 11-18-2006 | 08:39 AM
Dale's Avatar
Engine: 350 S-TPI
Thanks, I ran the vin and it was a v6 vin. Which explains a few other things. Now I wonder if it has a 305 or 350. UGH.
Old 11-18-2006 | 02:04 PM
3.8TransAM's Avatar
Block casting numbers will tell you.
Also should be marked on the top of the bellhousing on the engine.
Can also verify cyl head numbers by pulling off the valve covers and getting the numbers
later
Jeremy
MustangBeater20
10-29-2022 09:20 PM
fasteddi
09-10-2015 09:32 AM
Bubbajones_ya
08-31-2015 12:02 PM
ezobens
08-19-2015 10:29 PM
redmaroz
08-16-2015 11:40 PM
Quick Reply: question on "is this correct"
