Code 54 - Fuel Pump Question??
1 Post
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I am running a speed density TPI, and I have a problem with the fuel pump. The weird thing is the Fuel Pump (Walbro 255) is brand new. Sometimes when you turn the key the fuel pump will not prime and it takes a few seconds a cranking to get it started. Once running, it will through a code 54, but if I turn off the car and then start it again it works fine and no code. Anyone else have this problem before?
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Have you checked your f/p relay yet? The fuel pump willl not energize with a faulty relay but will get energized when there is sufficient oil pressure developed.
92camaroJoe
08-13-2015 06:07 AM
