suggestions on heads and cam
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
First of all before you go putting on expensive heads and a big cam you need better runners and intake baseplate along with headers and exhaust.If you don't do this it is kind of silly to run a bigger cam and good flowing heads because you will never reach the full potential of the motor.What is your horsepower and 1/4 mile or 1/8 mile goal? You can easily run 13s with just bolt-on parts.
The hot cam will work but you need aftermarket runners and baseplates because the Stock TPI falls on is a$$ after 5000rpm or around there. My brother has the SLP runners and elebrock baseplate and it pulls alot harder up top but the hot-cam can rev and make power past 6000rpm. I don't know if at that point you need a holley stealth ram or something like the accel superram but the SLP Runners and Elebrock baseplate would be good on a cam like mine, the zz4 or GM 845. ZZ4 208/221 474/510 112 lobe sep. or 845 214/224 488 509 112 lobe seperation.There are also cams built by LPE and TPIS. I would say stick with a 112 lobe seperation because it is more fuel injection freindly. Also with a Hot cam you are going to need a stall speed of at least 2500 and 3.42 gears to get some performace out of it. As for the 180cc AFR's they are bad a$$ and worth every penny but you have a long waiting list for them.A hot cam with afr heads will make 400+hp and you should be able to get in the 12s with some suspension work and sticky tires.
Hell I am in the mid-low 13s with a stock stall on my monte and I ran only 271rwhp,so I bet you could do it without the hotcam.
Alot of guys like the hot cam but I think it is to much for a daily driver 350 unless you run a higher stall and more gear.My friend had one in his zz4 and it was a dog till about 3000 and then it would wake up.He just needed a 2800 stall to help with the low end and now it runs good but it revs to 6000rpm and still has power.
For that amount of money I would just get the GM 845.It runs about a 100 bucks less and has the same characteristics. Alot of guys in 90's Impala ss cars run this cam.It will also run with a stock stall.What gears do you have? RPM range is 1600-5800 which is more of what you want.Also this cam has a slight lope.I have the zz4 and there is no lope but you can tell it is not stock.The 845 also has little or no lowend loss like the hotcam and makes about 10hp more than the zz4 cam.This is a very awesome and sometimes overlooked street cam!!!Go to scoggin Dickey or pace parts and you will find it under GM Performance parts cams.This cam is made by crane for GM.They make one from crane but it is 50-75 bucks more just because the name.The crane version is called the HR-276 part # is 109821. The only difference is the exhaust duration on the crane is 2 less then the 845.I know a guy who ran the 845 cam, AFR 180's, performer rpm intake and a 750 DP and he ran 408hp on the engine dyno and it is a very streetable cam.
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Great choice on the heads.
If you plan on doing the intake - figure that out first - before the cam! Valve timing is very important in LTR intakes, screwing it up can make the difference between a matched motor, and an engine that has no clue what it's doing.
Do you want to keep LTR? Do you want to do a "Stealth" LTR type intake by hogging out the SLP runners? Do you want to do the Superram for great peak torque numbers - and at the right place to ensure good HP numbers as well? (Can you tell which intake I like?) Do you want to do the HSR or LT1 and lose 40-60 lt/lbs of torque but gain 30-40 HP over the superram?
Basically what I'm saying is pick an RPM range - then the cam becomes much more easy.
Idle - 4800 RPM: What you have now.
Idle - 5400 RPM: Aftermarket LTR
1500 RPM - 6000 RPM: "Stealth" SLP runners or SuperRam
3500 RPM - 7000 RPM: Holley Stealth Ram or LT1
(Those are just examples: I know there's going to be some guy out there talking about the tire shredding torque at 1200 RPM he has with the HSR.)
Then pick the cam, once you know what you want to do with the car.
If you are going to get the baseplate and runners and not a stealth ram or mini ram (which I understand they are expensive) I would get a zz4 cam.You might be able to run something like the zz9 or 845 but I wouldn't go any bigger.You would have flow problems after 5500.Get some 1.5 roller rockers to top it off.As for new valvesprings you could call comp. or crane and they will get you what you need.Gm also sells Hyd.roller lifters too.As before they are made by crane for GM and are cheaper.Thats what is in my zz4.Basically get a cam that makes peak power 5100-5300.My zz4 makes a flat curve from 5200-5600 on the dyno and then falls off.For the baseplate and runners you could use TPIs but they are very expensive but have seen that the quality is far better then SLP.My brother got the edelbrock baseplate and the slp runners and it pulls to about 5400 just like GOY said and its alot cheaper.Check it out.Take your time and shop around.With those AFR heads you should make 280+rwhp which is more than enough to get in the low 13s if your car is set up right.Also you might want to order those heads now if you want them by the spring.I have heard that there is a 3month minimum wait for those AFR heads.
Have any of you heard of arizona speed and marine. I just talked to a friend of mine and he said he got some long tube runners from them. I looked at the runners from slp and they looked siamezed. From what I understand these are better for high rpm operation.
I have heard of them but did not know they made runners for the TPI. My friend had their headers on his 97WS6 a few years back and they were good quality.I take that back ASM everybody refers to them as around here. I just didn't put the two together.I have heard good things about them on the board.Do a search and see what comes up.They sure are not cheap though!!!
The AS&M runners are the bottom line best runners if you want to keep a "True" LTR design. Just do a search on them - I think there is someone in the 12.80 area with them and a host of other mods and dedicated chip work.
The SLP runners are only so-so out of the box, but can be modified beyond what any other runner can to do things that no other runner can.
Honestly, it sounds like the AS&M runner is your best bet since you want the torque, and don't really care about high RPM fun. If you did get the SLP runner - I'd suggest cutting an inch or more (however deep you can get) out of the top part of each "Runner Pair." You effectively enlarge the plenum space, and reduce runner length by doing this, moving your torque band up a few hundred RPM. In your case, full hog doesn't sound like the way to go, so don't be tempted to do so if you did go the SLP route.
I still hold that AS&M seems like a better match for your goal or keeping big torque however.
1 Post
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
The Edelbrock runners are bigger than stock SLP's . They can by ported and siamesed . They are DAM pricey though. But IMO look the best out of all of them. The ASM are only if you want to keep the stock look of TPI . I believe the Edlebrock runners have the highest potential out of all of them . The bast can be cleaned up to meat the speck of the Accel or TPIS one ( all same base I think )
I got 251/318 to the wheels with my take setup . ( runners siamesed 4 "deep) So with your AFR's and similar intake I expect you to get a fair bit more than mine with stock 3 angle valve job heads.
Here is my runners
Here is my runners
Do you have more pictures of the runners and the port job?? Have you ever measured "Final" runner length from the end of the siamese to the head port? Would you go on to say that you've made it roughly 16-17 inches in length? Can you siamese the runners all the way down to the base? I'm sorry for all the questions, but this is the first time I've seen it done with the edelbrocks, it's always been the SLP's that people do it with.
Also, do you have a dyno chart from your run? I'd love to see where and how the peaks occured.
1 Post
Car: 1989 IROC-Z
Yes I have a graph ...but it's untunned. Also others are getting a better peak with better heads/cam
I will try and dig up more of the runner shots for ya.
1 Post
Car: 1989 IROC-Z
Here is a different shot of the runners. I have another one but I am haveing issues getting it off my floppy disc I had it on.
I will be ordering the Edelbrock TPI High flo intake manifold. Is this the one you guys recommend or a different Edelbrock. Also do you guys think i should go edelbrock runners and baseplate or 'brock baseplate and SLP runners? by doing the combo is it just saving me money but reducing optimal gains in power? I appreciate your guys thoughts.
Huh, that's pretty interesting. You are making good power (assuming that's at the wheels), but I guess I was expecting the peaks to occur at higher RPM's all considered. Was it possible to siamese even deeper into the runners, or was that about it due to the angle of the bend?
1 Post
Car: 1989 IROC-Z
I expect a bit more power aswell . That was just a vette prom plugged in . So I think I can yeank over 260 to the wheels with tuneing.
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
good choice, ive got a friend of mine running 12.9 with the same intake, but with elb performer head. he also had the LT4 hot cam in it. it was a C4 with 323 gears with 700r4. you should be seeing 12s. givin' that you get a good tune.
do you plan on porting out the base and SLP runners?
84z96L31vortec
08-20-2017 12:16 AM
ambainb
04-25-2016 09:21 PM
84z96L31vortec
08-10-2015 08:27 PM
