Ford Blue top 24lb injectors on TPI
Car: 86 Z28, 86 Seville, 98 Isuzu Rodeo
Engine: 383, HT4100, & 3.2 V6
Transmission: World Class T-5
Axle/Gears: G92 3.23
no 305 anymore lol. I have a 383 going in .
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You will want to install an adjustable FPR when you install those Ford 24s for your 383 application. BTW: I am using those 24s in my 395 cu.in. stroker and have been using them previously in the 350 for about 6 to 7 years now.
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
I am sure there is a reason but why use ford injectors at 24# for $289. When you can get accel 26# injectors at summit for $269. Do accel injectors suck? I've only had a TPI for 9 months so I am still learning.
HEY DOC
HOW DID THOSE 24'S WORK OUT FOR YOU IN YOUR 395.MINE IS STOCK TPI PLENUM RUNNERS AND BASE W/ K AND N ON A 383. CAM IS A LITTLE AGGRESSIVE. WILL THEY HAVE TO WORK TOO HARD OR GO LEAN? I ONLY WANT TO DO THIS ONCE. WILL 22'S(G.M.) COPE W/ THAT SETUP?
Car: '87 IROCZ
Engine: 395 ZZ4
I do "burn" my own chips and I am running 52psi on the AFPR., please check sig. BTW: the injector constant in my best chip is set at 22.5. Therefore, with an AFPR, you might be able to go with a stock chip, however, since I am running a MAF, I needed a custom chip to get rid of the 33 error code. My best ET ever was last June at 12.19 sec. Adjust the AFPR until you get a good WOT AFR, and hopefully, the BLMs will correct the cruise around stuff.
Firechicken86
08-12-2015 10:07 PM
Sanjay
08-12-2015 03:41 PM
