80 psi fuel pressure??
Car: 86 Monte carlo ss
Engine: tpi l98
I have a tpi swapped into a monte carlo ss. It runs ok, but my fuel pressure is at 80 PSI. I swapped out the adjustable fuel regulator for a stock one, and there was no change. My only guess is that we got rid of the vapor canister and plugged the vapor line. Will that have any effect on the pressure. I don't think I have any fuel getting back to tank. Maybe something clogged.
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
If you pluged the return line it will boost the fuel pressure.
9192camaro
16
02-03-2019 12:21 AM
mdtoren
08-16-2015 05:45 PM
