EGR Valve Questions
Car: 93 TA, 92 GTA, 91 TA
Engine: LT1, L98
Transmission: T-56, 700R4
Axle/Gears: 3:23
EGR Valve Questions
What is the easiest way to remove carbon stuck in the seat of an EGR valve? Also, where is the EGR Valve letter located and what's the easiest way to get to it? (ie does the intake manifold need to come off)
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
there is no easy way to do it.
the EGR valve is mounted on the intake base, you have to remove the plenum & runners to get to it.
your hands must be smaller than mine, or you can move your fingers better, 30+ years of auto repair has taken its toll on my hands
i was able to get the EGR valve off on mine without pulling the runners, but i couldn't start one of the bolts with the runner on, seems like it was the drivers side runner i had to pull. its not a big deal so i went ahead & pulled the other side so all the gaskets would be new.
1992rs/ss
16
01-28-2016 09:58 PM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
