89 formula hard start
Car: 87 IROC
Engine: 5.7 TPI
89 formula runs good, but sometimes will not start. Will start w/ help of starting fluid. Im thinking tank fuel pump is going or bad fuel pressure. Anyone else encounter this problem. Any ideas???? Thanks
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Looks like Your onto something with the fuel but You should try doing a search. Go to the bottom of the page to the Forum Jump and the search should be on the top of the list. There should be much help there.
Car: 1989 firebird gta
Engine: sbc 355 hsr 280xfi 58mm tb
Transmission: raptor 700r-4, 2800 stall
same thing with mine
i have a 89 gta with the same problem, check your coil wires they will break inside the cover . have someone turn it over and you move the wires and see what it does.
92camaroJoe
08-13-2015 06:07 AM
