TPI OBDII - Thoughts/Opinions
Old 05-16-2008, 09:52 AM
  #801
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: TPI OBDII - Thoughts/Opinions
Got it, email sent. Thanks!
Ok I thought you were saying the 4x crank got the coil packs. UGH. Will have to see what this program says when it comes in.
I found that info on MSD's site, but it said they used a different plug on them. Dunno what went to what or how its wired. All I have visual access to is a 01/02? silvy with a 5.3. I know they dont look like the LS1's I see on summits site.
Old 05-16-2008, 10:06 AM
  #802
Dale's Avatar
Engine: 350 S-TPI
ok, here is a LS1 Coil, then Silvy 5.3 coil. then LS2 coil
Ok, from quick searching.
LS1/LS6 Coil "A", use plug "A"
LS2/LS7 Coil "C", use plug "B"
Vortec 5.3 in the silvy Coil "B", use plug "B,
Attached Thumbnails TPI OBDII - Thoughts/Opinions-delco-d580-ls1-coil.gif   TPI OBDII - Thoughts/Opinions-delco-silvy-5.3-coil.gif   TPI OBDII - Thoughts/Opinions-gto-ls2.jpg
Old 05-16-2008, 11:19 AM
  #803
S10Wildside's Avatar
Maybe I accidently posted something misleading. Can you let me know the post number and I'll clarify.
The Camaro/Firebird/Corvette coils use a metripack 150 connector and the truck coils use a GT150 connector. However, the coil harness is interchangeable with most (if not all) Gen 3 and Gen 4 engine harnesses.
Old 05-17-2008, 07:48 PM
  #804
I built the engine harness for the test engine today and loaded a modified 2002 Corvette LS1/T56 calibration into a 12200411 PCM. I'm using a used throttle actuator control module (TAC) and Corvette accelerator pedal. Going to use EFILive for the calibration work.
When this goes into the 1991 Trans Am I may use the E40 ECM (2005 Corvette LS2). It is smaller than the LS1/LS6 PCM and has electronic throttle built in. The only trick will be adapting the newer two wire knock sensors to the block.
The spark plug wires pictured are for a gen 3 truck application. They're a little too tight, so I'm going to have to find an alternative. For now they'll work.
Old 05-20-2008, 11:58 AM
  #805
We had just enough time today to crank the engine. It tried to run, so we adjusted the crank reluctor. Then it didn't want to run at all. Then we ran out of time. We'll probably make more progress on this toward the end of the week. We'll get it.
Here it is on the test stand, ready to run.
Old 05-23-2008, 06:10 PM
  #806
It runs! Here is a video. Notice it starts immediately after turning the key and the throttle response is right on when the electronic pedal is moved.
Click to view video.
Old 05-23-2008, 07:52 PM
  #807
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
thats awesome! Sounds pretty responsive too!
Old 05-23-2008, 08:49 PM
  #808
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
That is awesome and quite the accomplishment. Congratulations to all those involved.
Old 05-23-2008, 10:31 PM
  #809
Because the focus of this thread has been on the distributor-based calibration of the 12200411 PCM, I have created a thread in the DFI and ECM forum for distributor-less discussion. That way we can keep this topic focused on it's original topic.
Old 05-29-2008, 09:57 AM
  #810
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Hmm. I know what my next mod will be. Hmm. I need that whole setup in my boat lol
Old 05-29-2008, 10:41 AM
  #811
Let's do it! I have another Ram Jet 350.
Old 05-30-2008, 11:08 PM
  #812
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Give me a few months. I gotta pay off my wedding which is next month lol
Old 06-24-2008, 04:56 PM
  #813
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Does anyone know about how many people have used this setup so far on any kind of vehicle?
Ron
Old 06-25-2008, 07:03 AM
  #814
Dale's Avatar
Engine: 350 S-TPI
Thats why I was kinda making that list a while ago. But it doesnt cover the ones wildside has done on his own.
Id say its still less then 50. And when I tell people what I have done they are
Old 06-25-2008, 09:13 AM
  #815
I'd guess about 25 or so.
Old 07-13-2008, 09:46 PM
  #816
the highlander's Avatar
Well.. whats needed to use the COP on the lt1???? We all need only a crank reluctor ring. What does this ring need to have? i have access to a CNC machine from a customer of mine and he told me it was no problem building it. In fact. It was no problem building the complete timing cover...
If you can post a picture of the reluctor ring and the diameter and such I should be able to make one and test it out.
Subscribing to this.
Old 07-13-2008, 11:30 PM
  #817
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Cout me in for 2 of them !! lol. Still by far the best mod ever. lol Sad though that I have driven both cars about 100 miles each only this year. Just not into them anymore. I'm now buiding up an Vortec headed 350 for the boat. I'm confused with this carb stuff lol.
Old 07-13-2008, 11:49 PM
  #818
TGO - 10 Year Member
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have had 2 smallblocks running on the 0411 after doing OBDII conversions and am working on 2 more (ones a factory L31 in a 1997 G1500). The second is my 1983 G20 van with its TPI 310. I have a 1998 C2500 harness that I am re-pinning to run a 0411 and I will be using a 4L80E. 310 TPI, 4L80E, 3.08 gears.
Old 07-15-2008, 07:01 AM
  #819
Dale's Avatar
Engine: 350 S-TPI
Metal timing cover? I would love to see pics of that, and if price is decent, buy one from you.
Old 07-15-2008, 07:06 AM
  #820
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
I'd be in the market for the reluctor ring and cover, also.
Old 07-15-2008, 08:23 PM
  #821
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
Just need to install the harness. So you can add me to the list.
Old 07-15-2008, 10:39 PM
  #822
Redbird87's Avatar
Engine: 355
Add me to the list of those still working on this mod. I have the vortec, TPI, engine 75% done, (need to finish the heads) then installed the 88 GTA, but some health issues raised their ugly head and I had to delay the project for a few months but am starting once again. I need to get the wire harness yet but I believe I have everything else. At 67, I'm probably the old guy here but I'm trying to get this into Redbird soon. I've really enjoyed the thread. Thanks to you all. Dave
Old 07-16-2008, 05:24 PM
  #823
scuzz's Avatar
Engine: LB9
Axle/Gears: 3.55
Right behind you at 61, and my 41 pickup/Ramjet/0411 is not finished either. Real close though.
Old 07-17-2008, 10:04 AM
  #824
tpiselli's Avatar
Car: 83 T/A, 83 S.C., 86 S.C. & IROC
Engine: 305 CFI &TPI
Transmission: 4L60E, 700R4
Axle/Gears: 3.23, 2.73
Ron
Well you can count me in for doing this with a 305. It's been real slow going but I'll be finishing the short block this weekend. I pulled most of the vortec ignition components from a '97 Silverado. After removing the alignment dowls the vortec timing cover went on without a hitch. I plan on doing my own tuning as well as I picked up HPTuners not too long ago
Old 07-17-2008, 02:33 PM
  #825
novajoe's Avatar
Car: 86 IrocZ
Engine: 396
Transmission: t56
Could you post a complete parts list for the conversion?
I like that set up and need to do some parts shoping
Old 07-17-2008, 03:01 PM
  #826
Dale's Avatar
Engine: 350 S-TPI
that was my shopping list
http://www.rag-tops.com/index.php?op...&id=19&Itemid=
Old 07-17-2008, 03:40 PM
  #827
novajoe's Avatar
Car: 86 IrocZ
Engine: 396
Transmission: t56
THanks and now the draining of the bank acount begins
Old 07-17-2008, 09:34 PM
  #828
Dale's Avatar
Engine: 350 S-TPI
If you come up with GM part numbers on some of them items that I dont have them listed. Could you send them to me please?
Also. Alot of this stuff you can get used if you dont mind used parts. Mine is about 50/50.
Old 07-18-2008, 05:38 PM
  #829
scuzz's Avatar
Engine: LB9
Axle/Gears: 3.55
Except for my harness, I probably don't have 100.00 in the rest of the stuff.
Find a reasonable junk yard and become their best friend, and take off your on stuff so you get the nuts, bolts, etc., and it's cheaper.
Old 07-18-2008, 09:32 PM
  #830
This is worth repeating.
Some blocks (like the TPI engines) will require some extra silicone to seal the Vortec timing cover. I recommend taking a very close look at the timing cover and face of the block before installation. My approach has been to start the engine without the front accessories installed to check for leaks. In this way you won't have to completely disassemble the front accessories if the timing cover does leak.
Old 07-19-2008, 06:24 AM
  #831
Dale's Avatar
Engine: 350 S-TPI
Scuzz, including my harness and a TPI intake(since I was TBI), I have about 1g in mine.. Then efilive.
After looking, most of mine is new stuff, wow. My dizzy, timing cover, vortec coil(which I didnt use), crank ring, ignition mod are all new. I later installed new o2 sensors. Then the fuel pump.
My cover bolts, crank sensor, balancer, maf(which is now removed), 2 ecms, harness, are used items.
Old 07-20-2008, 04:31 PM
  #832
scuzz's Avatar
Engine: LB9
Axle/Gears: 3.55
The tough part is parting with another 7-800 for tuning software.
Old 07-20-2008, 09:08 PM
  #833
Dale's Avatar
Engine: 350 S-TPI
Agree on that.
Old 07-24-2008, 06:46 AM
  #834
One more step with the LS1 PCM.
Here is the 16mb video of it running. Click for video.
This is being disussed in the DFI and ECM forum.
Old 07-24-2008, 07:30 AM
  #835
tpiselli's Avatar
Dale,
Are you interest in part numbers for 305 engines or just the 350s? There's only a few differences (knock sensor comes to mind). Let me know.
Thanks,
Tony
S10,
I like you advice with this but I was wondering how you are supplying fuel for something like this? I see fuel line in some of the videos you've posted but I don't see where they go. Do you have a pump and tank setup off to the side which we just don't see or is there more to it than that? I ask because I should be close to getting my engine to this point in the near future.
Thanks,
Tony
Old 07-24-2008, 10:03 AM
  #836
Dale's Avatar
Engine: 350 S-TPI
Originally Posted by tpiselli
Dale,
Thanks,
Tony
Didnt think about 305's. But yea, if there are some differences, I'll happily post them on my site.
Old 07-24-2008, 11:47 AM
  #837
PonyKiller87's Avatar
Car: 87 Iroc Z28
Engine: 355 TPI
Are any of you guys running HP Tuner instead of EFI Live? If so any thoughs on how well it works for doing this project?
Old 07-24-2008, 12:16 PM
  #838
tpiselli's Avatar
I have HPTuners and will be using it for this. I'm not at the point where I need it yet (I'm still putting my engine together). So far I've only usd itfor basic DTC scanning and trouble shooting (like turning off the rear O2s on my '02 Z28) as well as some data logging. Hopefully I'll have more time with it as I get closer to getting this project going.
Old 07-24-2008, 04:52 PM
  #839
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.73
hey s10wildside, im gearing up to get a hold of you to order my harness still $600? im not going to be doing my own tuning who was the guy that was tuning these for people?
Old 07-24-2008, 09:06 PM
  #840
tpiselli's Avatar
Actually the knock sensor is the only thing I found different. Here are the numbers for a 5.0:
Knock sensor (5.0 liter Vortec), ACDelco part # 213325 or GM part # 10456287
Hope this helps,
Tony
Old 07-25-2008, 05:00 AM
  #841
S10,
Thanks,
Tony
There is a small fuel cell on the bottom of the stand, behind the engine. A high pressure Bosch fuel pump is mounted on the stand
Old 07-25-2008, 05:06 AM
  #842
The harness price has not changed. It may in the upcoming months...my costs are beginning to increase.
The tuner is no longer tuning. It was a step to get his priorities right...and I give him much credit for putting his family first. Your best bet is to find someone locally who can tune LS1 PCMs. I'm in Erie, PA. Where are you in PA?
Old 07-25-2008, 07:11 AM
  #843
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
im about 45mins. from state college if you would like to do the tune let me know now because if not then im not sure what i will do. really i would just need the pcm reworked so i could start my car and move it around a little when i work on it. i wont be ready for a full tune this year
Old 07-25-2008, 08:45 AM
  #844
Dale's Avatar
Engine: 350 S-TPI
Hope this helps,
Tony
Thank You. Added, along with edited a bit more of the info. If anyone else finds something they think needs to be added, let me know.
Old 07-25-2008, 10:23 AM
  #845
I will not be able to provide a tune. I'm avoiding mail order tunes. If I provide a tune and can't see the air/fuel ratio, I won't sleep well at night.
Old 07-27-2008, 10:33 PM
  #846
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Has anyone successfully gotten one of these to work on a pre-86 motor? Im still trying to figure out how to get the crank trigger to work with an older block.
Old 07-27-2008, 10:59 PM
  #847
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Yes, I have one on an 83 305. Just use a normal SBC single roller timing chain, the plastic vortec timing cover, and a Vortec 305/350 balancer. The hardest part is you will need to pull the 2 steel pins out of your block that are used to help position the stock tin cover.
Old 07-28-2008, 04:21 AM
  #848
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
so do you think i could get a mail order from pcmforless and have it work right till i get it to a tuner? i was going to go the way of no mass air or speed density since that seems the easiest choice and there will be a single turbo in the mix of all this. here is a some what picture of what my car will look like when its done.
Attached Thumbnails TPI OBDII - Thoughts/Opinions-evo2gtss.jpg
Old 07-28-2008, 07:26 AM
  #849
Car: 88 Camaro SC
Engine: SFI'd 350
DOH! Server cut my post off.
I will also be using a retro-roller, which is my main concern. I will need to use a timing set with torrington bearings and a thrust button, and Im not sure how well the plastic cover will stand up to the thrust button, and if I can fit a timing set that has torrington bearings within the vortec cover. I guess I could brace the front of the cover off of the water pump and hopefully the cover stands up to the cam button. The cam button will have bearings as well, so hopefully it wont dig its way into the plastic.
Also, do you have to shorten the balancer hub as well? I think the reluctor moves it a little further forward, no?
Old 07-28-2008, 07:47 AM
  #850
jwscab's Avatar
Engine: Many
Transmission: Quite a few
the vortec balancer is already shorter by the required amount for a standard chain, but it probably depends on what torrington bearing chain you go with.
Quick Reply: TPI OBDII - Thoughts/Opinions
