TPI on a sbc 400
Car: '89 Firebird
Engine: 305 TBI (LO3)
Axle/Gears: 10 bolts 2.73
TPI on a sbc 400
Will a TPI system will fit on my '71 sbc 400 w/stock heads and will it require PROM tuning ?
Car: 95 z28,86 iroc
Engine: 350 lt1,305 tpi
Earlier ones will dedpeding on the heads,but you will needs bigger injectors and such,depending on what you are running.{Prom,knock sensor and ignition control module}.
Car: '89 Firebird
Is it worth all the wiring or should I just go classic and make it carbed ? I'll drive it a lot ...
Car: 95 z28,86 iroc
It just depends if you are willing to buy bigger injectors,change the ignition module and knock sensor.This may add up in price,maybe {100.00-400.00}
if comparing used to new parts.
ambainb
04-25-2016 09:21 PM
Sanjay
08-12-2015 03:41 PM
