Accel/Lingenfelter Manifold made by Edelbrock
Car: 87' IROC
Aparently Edelbrock is now casting Accel's superram base. You can imagine I was pretty suprised to see Edelbrock stamed on the top of my manifold. Otherwise it still looks like Accel's original part. Does anyone know if there are any differences?
John
John
The Edelbrock part number is embossed on the underside of the intake manifold if made by Edelbrock. I think the number is something like 3890 without looking it up. See if the Edelbrock/Accel base has a part number on it. If manifold is different it might have a different part number.
1 Post
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Yes edelbrock does cast some (TPIS big mouth) intakes for other companies. Accel isn't one of them. My tpis has the edelbrock # cast in the bottom, but the top should have what ever companies name on it. It sounds to me like you got sold an edelbrock hi flo intake. How much did you pay for it?
Car: 87' IROC
1 Post
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
You should post pictures for us since a few of us have the Edelbrock base. The lot # on my base is less than a year old so I know its a more recent design.
1 Post
Car: 71 Nova
The quality isnt very good but this is my intake.
You sure they didnt just give you the Edelbrock one instead.
Guest
Posts: n/a
Doesnt look anything like the Accel base IMO.
Note the machined area at the distributor, not on the Accel. Check the spot beside the runners, the Accel has more material where the Edelbrock is chopped off. On the Accel, the mounts for brackets are all machined, the Edelbrock is not.
That kind of sucks. IMO the design of the Accel where it transitioned from the base to the head was a better design.
Car: 87' IROC
I could have sworn with the edelbrock you could see the outline of all 8 tubes like the stock manifold. I thought only the Accel had them blended to look like only four seperate tubes. I am wrong. That is incredibly disappointing. Does anyone know if there is a port size difference between the Accel and Edelbrock?
So much for getting my motor together quickly.
1 Post
Car: 71 Nova
The Accel,Edelbrock,TPIS bases all have the exact same dimensions. I wouldnt worry about it. Its in the FAQ. I hope you didnt pay more than what the Edelbrock base sells for.
https://www.thirdgen.org/accel-edelbrock-tpis-tpi
86IROC112
08-17-2015 02:00 PM
