Removing TV cable
Old 08-05-2006 | 06:31 PM
Quick-IROCZ's Avatar
Car: 1987 IROC-Z28
Engine: 305 Tpi
Removing TV cable
How do I remove the throttle valve cable from the 305 engine/TPI Unit? I'm swapping transmissions and I can't get the TV cable out.
Old 08-05-2006 | 09:16 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Its kinda hard. You have to unbolt the cable at the trans to get it off. It has one bolt with I think its a 8mm head. Then you have to un hook it from the arm inside the trans which is easy once you get unbolted and just unsnap it from the TB and remove from the cable braket on plenum. You can remove the trans with it on.
Old 08-13-2006 | 12:29 PM
dsherw00d's Avatar
Car: 68 Camaro, 73 Nova, 67 Mustang
Engine: 350, 355, 289
Transmission: Muncie, 700R4, C4
I just did this due to a broken clip on the trottle body side. I had to bend a offset box end wrench (10mm) to reach the bolt without dropping the rear tranny mount. Mine comes down at about a 45 degree angle about 1.5" from the end. Then about another 1" out, it comes just about straight down (clear the tranny edge). I could only turn it maybe 1/4 turn at a time. Make sure the offset end faces up - you'll know what I mean when you look at it. I bent mine the wrong way the first time.
Getting it off is the easy part, getting the new TV cable hooked to the arm is a PITA. Especially if your like me and only have the car on stands. If you have a lift, it may not be to bad. I actually dropped the pan since I wanted to replace the filter/fluid. It helped out a bit, but still took many tries (remember, I'm doing this with one hand since I'm on my back under the car). Then once it's hooked, you have to make sure it doesn't fall back out. It took me few hours to replace the cable - 30 minutes to remove it, 2:30 to get everthing re-assembled (seal, cable, gasket, new pan). A lift would sure make it easier. It's on my list for Santa
Make sure you get a new TV seal from Napa or the Chevy Dealer. It's much easier than trying to keep the old seal. Tha Napa one is about $3, the Chevy version is about $7.
-Dan
GeneralIesrussi
Carburetors
06-20-2024 07:21 PM
MY87LT
Aftermarket Product Review
06-07-2016 09:47 PM
TheTraut88
09-11-2015 05:16 AM
TheTraut88
09-07-2015 05:22 PM
Buickstaged
Brakes
09-04-2015 07:53 AM
Quick Reply: Removing TV cable
