TPI VS LS1
TPI VS LS1
HI EVERYONE I HAVE A TPI 89 IROC Z 350 I LIKE TO REBUILT IT USEING A BETTER CAM ALUMINUM HEADS WHAT KIND OF PISTONS I USE I LIKE TO HAVE 9.5.1 COMPRESSION 93 OCT IS GOOD TO USE OR 10.1 COMPRESSION WILL 93 OCT GAS WORK IF IT DOSE ITS GOOOOOD I WILL BE TUNEING THE ECU COMPUTER AT JETCHIP.COM DO I USE STOCK ROCKERS OR 1.6 ROCKERS WHAT ELS DO I HAVE TO GET RIGHT TO RUN LIKE A LS1 I LIKE TO GET 350 HORSE POWER OR BETTER WITH THESE MODFICAION WOULD IT BEAT A 2002 LS1 STOCK CAMARO BY A FENDER OR A CAR LINK OR BETTER I WILL ALLSO BE PUTING SLP RUNNERS IN BETTER MANNIFOLD IN TB 52. MM OR DO I NEED 400 HORSE POWER TO BEAT THEM IN WILL THE TPI TAKE IT HELP GUYS LET ME NO IN ALL SO 342 GEARS WITH TRANNY THANKS
Car: 2004 GTO
Nitrous.
You will edge an LS1 up to half track with the low end torque, but will get smoked after that if you are using a long tube runner.
ambainb
04-25-2016 09:21 PM
NBrehm
08-25-2015 11:49 PM
Sanjay
08-12-2015 03:41 PM
