42 lbs/hr SVO injector question
Car: Dark Blue 1987 Chevy Iroc-Z Camaro
Engine: 5.7 350
Axle/Gears: 3:42
Everybodys selling me to get 42lbs/hr for my engine setup however I cant seem to find svo injectors anywhere ? Where can i get a set of 8 of these ?
Engine: 5.7 350
Axle/Gears: 3:42
350 .040 over thus giving a 357 4 bolt main
AFR 195cc heads 68cc combustion giving 9.5 ratio 2.02 int flowing 260cfm at .500 1.6 exh flowing 190cfm at .500 lift and my springs are limited to .550lift
Hooker 2055 Headers along with 3" exhaust
TPI setup stock at moment however will adjust this to match afr 195cc head flow numbers or as close as possible.
Vortec V1 Supercharger will be running low psi around 6-8
Comp Cams 224/236 Duration , 502 / 520 Valve Lift 113 Lobe
42 lbs /hr SVO Injectors
T-5 Borg Warner Transmission
Full MSD ignition with boost timing retard box
Taylor 8.5 wires
Seal Pro Forged Pistons
Comp Cams Roller Lifters
Comp Cams Roller Rockers 1.5 ratio
Forged Alloy Push Rods
thats why i need 42's
Taylor 8.5 wires
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Translation:
For those of us lazy type people.
Originally Posted by Destructive099
It is a blown application.
