Permanent schrader valve gauge?
I seen a few pictures, but I can't find them! I just was looking for a small one that you could screw in and keep it there to adjust fuel pressure. I don't want one with any plumbing or anything.
1 Post
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Accel makes one. I have one on my car. I got it from summit. There are two part numbers. They are both the same but one comes with a relocation bracket for the MAP sensor on SD systems. Part ACC-74726 is for speed density cars and ACC-74745 for MAF cars. It is a nice guage. Small enough to not take up to much space but big enough to read the guage.
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
although the accel one says not to be used permanently, i have an s&p polished fp gauge that i had on my rail, i took it off for a interior mounted one
Well I got it, and it said it has been "repackaged". Right part #, wrong part.
The one I got looks like this (does not fit):
When it's suppose to be this:
Hotrodboba400
12-10-2019 07:07 PM
