timing question
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
timing question
what do you disconnect when you set the timing on tpi cars???? i need to set timing on my car.... and what should it be set at???
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
on my 87 its a brown wire with a black tracer near the ( if u have ac) ac condenser firewall area
gl! 6 Degrees for a 350 10 for 305
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Sorry to bring this post back up......so I disconnect the wire.....set the timing, then what? Just plug it back in? Or is there a process that you have to follow?
Car: 1988 Trans Am GTA
Engine: 383
Another thing. I'm sure you've researched it but TPI cars like timing. So I would set it at 6* in the begining, but play with it afterwards to find where the car pulls best at. I have read many articles where stock TPI'ed 350's like as much as 12* btdc! See where yours like it.
Car: 1987 Trans Am
Engine: 5.0L TPI
Yeah I just put the Edelbrock intake and runners on along with a new cam and some other toys too.
I'm trying to fine tune it a little bit before it goes to the dyno. After that they can custom burn me a new chip.
