Maf Codes + o2
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Maf Codes + o2
Quick question, been noticing since i replaced my maf ( runs very good compared to before still a tiny miss but i can deal with it)
after 30ish cruising ses light pops up
Check codes when i get back 13,33,34,36
Do you think the o2 messing up would make the maf code pop up? ( brand new burn of relay and MAF if idling and reving etc, will produce no codes)
Test the power and signal at the MAF with the engine running, then monitor the MAF during shutdown/burnoff. I'd suspect your new MAF didn't solve the problem, and now you get to perform the diagnostics which should have been done before replacing it.
Is the MAF power relay good?
Car: 1988 IROC-Z
Transmission: 5-speed
Axle/Gears: 3.08 stock
Yes, the O2 sensor can cause the ECU to set MAF trouble codes. Test your MAF like Vader said and if it checks out OK, buy a new O2 sensor if you haven't already.
Oh, this may be a stupid question but, did you clear the codes from the computer after replacing the MAF?
Axle/Gears: 3.23's
Ive done the diagnostics, before it was a bad MAF, threw a 36, i diagnosed it to be a bad maf from the troublechart it needed a new burn of relay.
It didnt help it so
I boughta reman maf, made it run so much better
I had used a snap on scan tool, dont have access to it now since out of shop ( summer wont be back till september)
Never measured the output of the maf during idle etc how is this done?
It didnt help it so
Axle/Gears: 3.23's
Alright, ill try that
I believe blue is the output wire ill go check that
Another thing that accured to me is maybe i should just replace the o2, reset the computer and see if it sets a code
Its wierd because i can let it sit forever reving and such never throws anything,
Only when your cruising do's it
Ground the meter at the black wire (terminal B) and positive at the green wire (terminal C) and meausre the voltage signal at idle.
You should read around 800-900mV on a 350 at a normal idle RPM:
Axle/Gears: 3.23's
Was idling around 900
i got a .840-60 ish reading, flucuated a bit
im gonna reset the ecm and see if itll pop the codes up again, ( just checked codes 13, 33,34,36, 42
Axle/Gears: 3.23's
Wasnt able to drive today, Probly tomorow
any other tests i can do?>
Axle/Gears: 3.23's
Reset the ecm and took it for a ride was fine then code popped up
then i pulled over and checked them
13,33,34,35,42
All at the same time it seems, im thinking a new o2 would cure the problem( maybe est as well)
13,33,34,35,42
That MAF output is just about perfect. Nothing wrong with that piece of hardware.
You might want to verify good connections between the MAF and ECM, and keep an eye on the TPS signal. As long as you're checking, be sure the TPS has a full 5.0V reference voltage. May want to check ECM and engien grounds again, too.
Was that a typo, or did you actually get a "35" error code?
Axle/Gears: 3.23's
typo, was a 36 as usual
my question is there a System ground that is related between the 02 and maf systems or is it just coincidence the codes pop up at the same time
my tps is set at .56 and near 4.5volts WOT
i notice around the 2 volt range it goes to 0.00 so i think its a bad sensor
Would this make the codes pop up
Boston - We have a problem...
If the TPS falls off to nothing part way through the sweep, it is probably failing. When the TPS signal falls off, the ECM will interpret the MAF flow at too high for that throttle angle (33). You at least need to resolve that TPS problem. That may clear up one or more codes, then you can procede.
Axle/Gears: 3.23's
just bought new tps, installed and set to .54
Then tested it.... turns out it go's O.L at 3.9-4.0 ish volt
But thats only about wot, so.. better then the previous tps and its way to hot to be running back and forth lol
ill give it a test drive in about a hour
Axle/Gears: 3.23's
been driving it lately, ive narrowed it down
ONLY when i get a code 24 do's everything pop up/go crazy
it was converted from an auto, but atm speedo/vss isnt working
So, code 24 is when its above 1700 in P with no throttle
and keeping that in mind, instead of let of the gas, i would push in the clutch etc
no codes popped up unless i slipped up by mistake
ALSO
have 175 bucks to spend on car, still has a vibration to it so im thinking, New performance plugs..gapped to .35 Accel 50k coil, and some taylor wires to get it all there and make it run smoother, then fix the vss/speedo when i get back into shop ( sept)
ALSO
