Help with leaking fuel rail schrader valve
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Pulled the plastic cap off to check fuel pressure and lost it somewhere under the dist or manifold. Checked fuel pressure, pulled the fitting off when I was done. Without that plastic cap on the schrader valve, fuel shot straight up into the air.
So I just screwed the fp guage back on so I could drive. I cant find that stupid cap anywhere and am having a bitch of a time finding one.
Checked parts stores and they dont have them. Seems like an easy enough thing to find but I am having trouble.
Any advice??
Any advice??
unfortunately I have not been able to find any pick n pull's in austin texas. There were plenty in Dallas. I'll have to look again.
ok..thanks for the help. I'll give it a shot
Are these things supposed to leak without that cap on it?
Thats what i thought too....Dont know why fuel shot out unless the spring on the valve stem is just old and weak.
R3500
08-17-2015 12:16 PM
