smog equipment delete, will this cause engine light
1 Post
Car: 89 formula and my late 86 iroc R.I.P girl
Engine: 89 firebird formula-305 tbi,86 iroc 305 tpi
Transmission: both 700r4
i want to get rid of all that air injection crap to clean up the engine bay, will this cause a check engine light
Smogpumpremover (10-01-2023)
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
not sure... but so far mine has not
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Not on my 1990 Iroc. Smog pump and air tubes are gone, as well as other miscellanious crap.
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
No CE light will activate.
However for proper operation of the rest of the systems, you should have a custom chip made to completely disable the AIR settings as they do affect the 02 sensor when active. Its an offset
later
Jeremy
later
Jeremy
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: smog equipment delete, will this cause engine light
you can remove everything but the egr i would leave that to prevent any problems
Car: 88 gta
Engine: 350 HSR
Axle/Gears: 3:27 borg warner 9 bolt
pull all that junk out and unhook the egr valve ive deleted the whole tpi system no codes on stock ecu
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
kevin we keep on doing this little dance, illegal versus street legal. lets just agree to dissagree.
yes, its illegal to tamper with emissions stuff yadda yadda
but
yes, it gets in the way. yes you can remove all that stuff and still pass smog, yes, itll clean up the engine bay.
but the decision is up to you.
and no it wont set off a CEL
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i have a ? how many block off plates do i need when i remove the rest of my emmisions. i know 1 for the egr and wheres the other also where can i get these plates. also what do i do about the vacume line that goes to the egr
Car: 88 gta
Engine: 350 HSR
in some states they only look 4 a catalitic converter and do tail pipe emisions and check engine light for 95 and after
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
The EGR doesn't use engine vacuum, it source is throttle body ported vacuum nothing else should be using that port's vacuum.
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
so what do i do just block that vacume line that goes from the egr to the plenum
Keep the stuff on your car. Eventually Obama is going to make every state do emissions testing as he tries to create a happy green USA for us all to live in. If you dont have the parts its going to cost you a LOT of money to buy them again.
Also, in the meantime, every time you remove your emissions devices, you are telling the smog-***** that the current laws are not tough enough to stop you, so now they have to write tougher laws that affect the rest of us. Thanks a lot!
We here in SoCal have proven that you can have a fast TPI car and still pass the emissions test. You dont have to remove anything because its not going to give you much gain, if anything at all. I removed my a/c and I can access both sides of my engine very easily, even with the AIR lines.
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
apparently they put something in the water in California to brainwash people
Kevin91Z is right. Emissions testing is not going away, eventually it will be in your county no matter where you live. I'm proud that my 20 year old car runs cleaner and gets better mileage than a brand new pickup.
Car: 89 formula 350
im certain that after a certain age there will be exceptions to the laws...
Car: 1987 Trans Am GTA
Axle/Gears: 3.73's
Here in Ontario, anything '88 and newer must have an emissions test every other year....
Car: 88 gta
Engine: 350 HSR
in tennessee anything after 74 has to go thru emissions accept 1 tons and diesiels
Car: 89 Firbird Formula WS6
Engine: TPI 305
Transmission: T 5
Axle/Gears: 3.45 Posi 9 bolt
smog pump, air tubes, and cat are gone on mine and no problems from that. Still have the EGR hooked up though
Car: '91 Z28 305 TPI
Transmission: Manual
I removed my smog pump this weekend as it froze up on me. I left the metal tubing that goes into the manifolds but capped them (x3) with 1/2 iron pipe caps.
My check engine light came on.
Any suggestions?
Do you have to do anything with the two plugs that were unplugged?
Any suggestions?
Transmission: T-5, TH350, T-5
Any suggestions?
Any suggestions?
Good advice. The speed-density system from '91 should not be looking for the electrical load (35-50Ω) from the port or divert solenoids as a later ECM/PCM would. Don't be surprised if the O² sensor is reporting lean, potentially from a leak in the caps you installed on the air injection fittings. The threads are not NPT, so a standard pipe cap may not seal very well.
T.L. (09-06-2022)
Car: '83 Firebird (T/A Clone)
Engine: 350 carbed with L-69 components
Transmission: 700R-4 w/2000 RPM stall converter
Axle/Gears: 10-bolt/3.73 ..
I try to tell people that and they just ignore me. The threads are 1/2"-20. People refer to the fittings as 5/16" inverted flare. Well the flare may be 5/16", but the threads are 1/2"-20 which is a bolt thread, NOT a pipe thread...
Car: 96 WS6 Formula Ram Air SLP
Transmission: 6 spd
Here is what you need to plug holes in manifolds.......
or this.....
https://www.rockauto.com/en/moreinfo...854912&jsn=255
Engine: LB9 305
Transmission: AT
AND, in Cali, they will release a kidnapper/rapist/murderer, to make room for YOU!
Or these (and that's not rust. It's copper-colored anti-seize)...
BizJetTech (09-07-2022)
