View Poll Results: which should i get
VORTEC TPI
47.62%
HSR
52.38%
Voters: 21. You may not vote on this poll
vortec tpi or hsr?
Car: 89 WS6 formula firebird
Engine: 305 TPI :(
vortec tpi or hsr?
help me out here guys, i got a vortec 350, lt4 hot cam, with crane gold 1.6 RR;s comp. ratio is 9.5:1, which should i buy? the SDPC vortec TPI or HSR?
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
If your keeping the 2:73 get the TPI.
If u want to go as fast as humanly possible get the HSR.
Been there, done both.
I'm still very partial to TPI though as that torque kick is very hard to beat, t just cant pull up top.
Cant vote until I know more about your plkans and car.
later
Jeremy
later
Jeremy
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
will since neither are gonna pass visual unless you plumb the exhaust externally on the vortechs, go hsr, more power capability, less torque, but you can take it right off the 350 down the line and put it on your 406 torque maker!
HSR
HSR
Engine: 305 TPI :(
ok im going 2 list some things that i will have on my car, like i said before iv got a vortec 350, lt4 hot cam, with crane gold 1.6 RR;s comp. ratio is 9.5:1, with a 700r4, going to put 3.73 gears, and 1 5/8 headers, and some suspension mods. and im also partial to TPI, people bad mouth it so much, id like to run 12-13;s and say ya, its gotta tpi im pretty sure that i am going to put the sdpc tpi kit on because i could simply sell the base plate and what not and go for the hsr if im not satisfied, but please post your comments thanks.
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
I would say TPI since it would be more fun on the street. If your reaching for better 1/4 mile runs then get the HSR. Im running the Superram since it has a little of both worlds. A Superram vortec would be pretty sick.
Engine: 305 TPI :(
What kind of numbers would i see from a vortec tpi with stock upper parts, and what would i get with hsr, judging by my parts.
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
personaly TPI all the way. i say we show the other guys what real torque is like
i plan to build one myself. probably 383 with AFR 195cc heads and big cam, i am shooting for 11s.
Engine: 305 TPI :(
vortec heads. i might do some port matching and some other stuff but not really to much to the heads, im shooting for 12.s
Car: 1988 IROC-Z
Transmission: WC T5
Check out the SDPC site. They have dynoed some different Vortec combos and have the results posted at the following link:
Vortec TPI Intake Baseplate - Scoggin Dickey Parts Center
Steve
Steve
Fast355
12-02-2016 06:33 PM
Sanjay
08-12-2015 03:41 PM
