should i?
Old 05-21-2006, 03:03 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
should i?
Should i use this cam or do you guys think it would be to much? its for a 305 tpi 5 speed with 3.08 gears. I would also be running tpis runners and base, and headers with it.
Old 05-21-2006, 11:23 PM
phoenix305's Avatar
Sorry i don't know why but i won't let me link anything so here are the specs.
Product Line: Competition Cams Xtreme Energy 4x4 Camshafts
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,500-5,500 RPM
Intake Duration at 050 inch Lift: 220
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 220 int./224 exh.
Advertised Intake Duration: 270
Advertised Exhaust Duration: 274
Advertised Duration: 270 int./274 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.474 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.474 in.
Valve Lift with Factory Rocker Arm Ratio: 0.474 int./0.474 exh. lift
Lobe Separation (degrees): 111
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: Yes
Grind Number: CS X4 270HR-11
Old 05-21-2006, 11:27 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
looks like a good street cam
Old 05-21-2006, 11:48 PM
phoenix305's Avatar
Do you think it has to much duration, says it will make power to 5600 but even with the tpis runners and headers i'm only expecting it to pull to about 5100-5200.
Old 05-22-2006, 09:23 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
the extra duration is good for tpi cars. and i dont think that it is too much. it should run good. with that cam you will have an asome choppy idle.
Old 05-22-2006, 10:33 PM
phoenix305's Avatar
Alright thanks.
