Biggest heads for 305 TPI?
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
The 215 are too big, the largest intake valve that will clear the 305 bore is 1.94" and the 215's have 2.08" valves. The heads that will fit are 180 AFR, the new trick flow 175 head, E-tec 170's, Vortec heads, and L-98 alum corvette heads. I am sure other will work but these are the performance heads that will work.
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Originally Posted by Speed_Kills
There's no way to make power with those small heads. Looks like i'll just be doing a superchargerd 5L instead.
Axle/Gears: 9-bolt/3.45
According to its flow rates, the Trick Flow 175 should make excellent power.
Summit's site even says the GMPP Fast Burn heads fit a 305 too, though I think that'd be an awfully tight fit.
And playing on Desktop Dyno, both heads, theoretically, produce very similar results.
Flow rates for the GMPP head can be found at SBC Cylinder Head Info But the Trick Flow rates on this link are for the 195 head, not the 175. You'll have to go directly to Trick Flow's website for info on the 175 head.
Car: projects.......
- Larger heads DOES NOT = more hp. Too large of a head will lower hp and drastically lower tq, thus making much less power than a properly sized head. I'm running 11's in a 4000lb car with un-ported 200cc heads, what are you expecting?
Sanjay
08-12-2015 03:41 PM
