install aftermarket tach???
Car: 96 impala
Transmission: 4L60e
i have a 1987 camaro 350 TPI and i was wondering if anyone knows where i can get the reading off of my distributor in order for my after market tachometer towork. what wires do i splice in order for my tach to work? what is the color of the wire????
Car: projects.......
...should be white wire on coil unless someone has f'ed with your wiring. Make sure you wire the tach hot wire to an ignition + not constant +. I've seen too many people with dead batteries......
1990, 89, aftermaket, aftermarket, aftermatket, camaro, engine, install, tach, tachometer, techometer, tpi, wire
