interesting situation
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
I've been having an intermittent problem with the car running into a brick wall at about 4,000 RPMs at WOT that’s recently gotten worse. It’s fine if you walk the car up past 4,000 but the instant you nail it the engine acts like it’s hitting a rpm limiter and feels like it fuel starves its self. You can take the car all the way to redline in gear at part throttle though. If you stay on the gas after it happens the engine will rev down to a certain point around 3,700 and then it will act normal again (ie rev quickly back up) to around 4,000 and then do it again.
The tack doesn’t fall so I’m assuming I have ignition. I hooked up a fuel pressure gauge and drove around and pressure wasn’t falling off so I’m assuming I also have fuel. Fuel pressure was fine @ idle and pressure would gradually work its way up a few more pounds as you get on the gas then it would level out by the time I hit about 3,000. The needle didn’t budge when I hit the 4,000 limiter thing.
The thing to figure out is this: what sensor input would cause the engine to lose either fuel (injectors shutting off) or spark at 4,000 RPM (it’s almost always exactly at 4k) but only under load?
I assumed MAF and replaced it yesterday. The car drove perfectly after that. I thought I had fixed it. I drove to Princeton in the rain later that afternoon with no issues. The next day I took a friend out for a ride and it did it again right at 4,000 RPM.
I have a functional ram air hood. Is it possible that the water killed the brand new MAF? Did I just get lucky on the way to Princeton since the problem is intermittent? Anyone have any ideas?
Car: '89 Iroc Vert
Engine: 355 TPI
Transmission: T-5(for now)
Axle/Gears: 3.45 9 Bolt
i've seen problems that occur at exact rpms cause the spark is tracing in the cap
Car: 1986 Z28
I have seen weak ignition coils cause a similiar problem. Also, if the coil wire is bad, it can cause weak spark that only shows up under high load situations.
Car: 88 GTA
Originally Posted by 88 IROC CONVERT
change fuel filter lately? sounds like its starving up top
Originally Posted by 89Vert
whats your distributor cap look like?
It still boggles me that it will only do it under load.
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Before swapping out parts, pull your ignition module and have it tested. Don't forget the correct compound for under the module, dielectric isn't meant for it. If you need a part number look in the 'accel module' thread in the aftermarket review board.
Location: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
This RD's post that he mentions above:
Originally Posted by Red Devil
I've found that most of the modules are comparable.
Since we are on this discussion, I always feel the need to add this in as I constantly see people doing this.
Do NOT use dielectric grease under the module, use the right stuff, thermal heatsink compound. Many of the box store ones come with the dielectric crap. What you want is the white or silver colored stuff.
Wells part # SL-203. And make sure the parts boys give you both tubes in the box, lately I've had the parts boys pulling out one tube from the box and trying to charge me the full price. It should be two tubes in the Wells box, IIRC blue and white box.
Car: 88 GTA
Thanks for the heads up on the ignition module. I'm going to take a DMM to my throttle position sensor tomorrow when the sun is up to eliminate that off the list.
Where can I get the module tested?
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
first thing i would do is hang a gage & check fuel pressure when it you nail it.
if you have the external coil, pull the coil wire off at the coil & have someone crank it over, if the coil is good it should be able to fire down the side of the tower to the laminations
Car: 88 GTA
Car: 88 GTA
small update: checked the TPS. .48 volts closed 4.3 WOT. No dead spots. I'm going to try to adjust it to spec (0.54Volts +/- 0.075Volts) closed and we will see what happens today in my driving.
Car: 88 GTA
Another update: it basically has to be the MAF.
Earlier today I adjusted the TPS to no avail. Then I talked to one of my friends about it. He told me that since I was running a pretty old computer I could just unplug things sensor by sensor (MAF, TPS, coolant temp, etc) until I found the culprit. TPS checked out fine. I plugged that in and unplugged the MAF sensor and the car ran right to redline in first.
I guess the reman was a POS and I managed to kill it in a day. Damn expesnive reman to at $220.
Car: 88 GTA
Just got done installing the second MAF. Still no luck. I checked my wiring extension and everything checked out ok (had to extend the wires going to the MAF for the ram air intake). Everything measured @ .6 ohms or less. There was one weird thing though: the black wire and the black/white wire were continuous. Anyone know if they’re ground wires?
I’m going to go back to step 1 and unplug the sensor again and see if I can still get it to redline in gear. Maybe I got lucky last time?
If anyone has any additional ideas I would greatly appreciate it.
Car: Tree Huggers
Engine: Do Not
MAF relays. Lookj around there are a few threads going right now about MAF problems, and I think those two wires may be grounds, I don't have a schem in front of me.
Car: 88 GTA
Car: 88 GTA
Where are the relays located? I did a search but didn't find a ton of info, only that the two relays are two different part numbers, autozone only lists one number, and it doesn’t physically fit in both spots.
I got the complete wiring diagram for the engine bay and there's only one wire that actually goes to the ECM from the MAF other than a ground reference and it looks physically in tact in the car. I will check resistance through that wire tomorrow but it should be fine.
I'm really at a loss. I tried unplugging the sensor and driving around today and it was perfect aside from not running 100% for obvious reasons. This means it’s either the MAF circuit or the computer does something with the MAF unplugged differently than when it’s plugged in. The WOT thing still bothers me. I almost think it has to be ECM related?
If anyone has any kind of advice I’m more than willing to listen.
Car: Tree Huggers
Engine: Do Not
Photo courtesy of Vader:
Many are the same (power and burnoff - I've never actualy seen those two not ne interchangeable, but I've heard the rumors), some use the same for the MAF as the fuel pump as well.
The difference is that the computer goes to predetermined tables in its program when it has a major fault such as a non-responsive MAF. If you want some good reading do a search with MAF and user name Vader. He's written more that I have.
Car: 88 GTA
Nice picture. I can tell you visually that my relays are different for the power and driving lamps – mine are somewhat oval looking, like the fan relays for the dual cooling fans. I know it's getting power because I swapped those two. The burnoff relay might be bad though - I've got nothing to swap it out with. I wish there was some way of testing it.
Wouldn't unplugging the TPS count as a major fault? I know that sets a code and turns the check engine light on. The engine still falls on its face at 4,000 even with the TPS unplugged.
At 4,000 RPM (or whatever RPM) with the throttle open 80% or more, the ECM may not even be looking at the MAF. Well, technically, it would be monitoring the signal, but not using it for fuel calculations. Once the MAF is maxxed out for flow, the ECM is only fueling based on tables, not the MAF input. You may have modded the engine enough and improved VE to the point of being beyond the capability of the stock programming.
If you don't find the problem in the ignition, you may want to consider that possibility.
Car: Tree Huggers
Engine: Do Not
The pic is of an '86 set-up. My last '89 were all oval and both the MAF relays and the f/p relay were the same. :shrug:
Car: 88 GTA
edited:
That's exactly the kind of answer I was looking for. I'm willing to be that the engine hasn't been modded to get past the point of the stock programming. The problem has been gradually getting worse over time (no additional mods) so it makes sense that a part is failing. It could be ignition related but I've got no idea why it would suddenly be better with the MAF disconnected?
What ignition related things should I be looking at?
Car: Tree Huggers
Engine: Do Not
Hmmm... looks really familiar... I take it you never did it? You have two projects for tomorrow.
Car: 88 GTA
This brings me back to my other question:
1 Post
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
I had a simular problem with mine even. I dont have a maf though but my o2 sensor had backed out and wasnt getting the right signal and was dumping to much gas in at 4+k. It seemed like it was hitting a rev limiter.
1 Post
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
I Know exactly what you are talking about....I recently had the same issue as you but fortunately for me I own 5 of these cars and had plenty of spare parts to test with.....I replaced everything.....
For starters a few specs
350 .40 over
High Rise Cam
69 Fuelie Angled Plug Heads 2.02 1.60 Valves
SLP Ported and Polished Siamease Runners
Ported and Polished Plenum
Car ran like Brass then one day went to punch it and like you said it hit a wall just like a rev limiter....
Thought MAF sensor...Swapped in a New One had still in box no help.
OK next Pulled MSD 6AL Box....Still no help
OK next Swapped in new Ignition Control Module
Still Issues so I then swapped coils nothin
Next camp ECU still no help... Then Prom Nothin.
Then IAC and TPS Nothin
Checked my Holley AFPR and my Walbro right at 50 where set
ok Checked timing dead on....
New Cap and Rotor Still problems...
OHM tested my MSD Wires they were fine...
I was running out of ideas....
Then swapped MAF Power and Burnoff Relays No help
Tried the ESC Still no help
After all that it boiled down to a bad connection from a wire splicing i had done between the Harness and the ICM.....I pulled it apart soldered it back together shrink wrapped it and have been running like a champ ever since.
350 .40 over
High Rise Cam
Car: 88 GTA
Where exactly is the ICM?
91RS5speed: thanks for the idea. I will check that as well.
1 Post
Car: 85 87 87 91 92
As far as I know there's nothing spliced/soldered by the ICM. I spliced on one of the two molex connectors going to the coil because I broke a pin in the orginal but the problem existed before hand.
Car: Tree Huggers
Engine: Do Not
...Or how can I test it myself?
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
Is there any way of testing the coil without replacing it? I hate to say I'm on a budget because I'm usually willing to just replace stuff but I'm out of a job for another two or three weeks while they repair fire dammage at work
Car: 88 GTA
Thanks for the info guys. I'm not going to have a chance to do this today because I've got too much stuff going on but hopefully I will be able to get to it over the weekend. I will keep you guys posted.
Thanks for the help/advice so far
edit: purpleZ-28 - the car starts/runs fine. Well, it is starting a little rough but that's no the main concern right now. My problem lies at 4,000 RPM at wot. I will be looking into the coil though.
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
HAve u tried cleaning all the grounds yet?
Most ecm grounds are on the pass side rear of the cylinder head.
Might want to make sure they arent broken or extremely corroded.
Seen similiar problems from it as well.
later
Jeremy
later
Jeremy
Car: 88 GTA
later
Jeremy
later
Jeremy
