Dynoed Full Bolton L98
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
just got back from the dyno. The car has pretty much ever bolton,still has stock heads and cam. Best pull made 251.29 HP and 293.34 Max Torque at the wheels... Looks like I'll be needing cam and heads to see 300 RWHP....
typical. not bad at all.
some heads and cam will really wake that motor up.
post before and after dyno numbers after the heads and cam go on. let us know the full specs on the cam and heads too
thanks
thanks
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Interesting. At first I thought this was still with TPI intake but I see you are running the super ram and big base. For comparison my L98 all stock except SLP 1 3/4 headers and pullies gave me 229hp/330ft lbs (SAE correction) at the rear wheels.
Heads and cam with your intake and you will have a monster though.
Really sharp looking car BTW.
-Schultzy
-Schultzy
Car: 89 Formula 350
Originally posted by Tony89GTA
Have any track times? BTW killer looking Formula!!
1 Post
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Did you measure the A/F with a wideband, or did you calibrate it well before the dyno pulls? If I had to guess, I'd say you're on a Mustang dyno (dynojets have a fudge factor that boosts the numbers).
The ARAP bin isn't necessarily the best thing for your engine (iron heads). It uses the knock sensor extensively, which can over-retard. ARAP has good fueling though, so they say, but did you change the injector constants to compensate for your fuel pressure? The ARAP PE is still quite rich, and targets about 11.9:1. With the extra fuel, it's richer of course. I've found peak torque with rich mixtures - high 11's, low 12's, and peak power with mid to high 12's.
Car: ws6
Engine: ls1
Transmission: m6
Re: Dynoed Full Bolton L98
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
JulieGTA(92 GTA) on the southern Cal. board made 253rwhp@319rwtq with these bolt ons. TPIS Big Mouth manifold, Edelbrock runners, 1 3/4 headers with dual 2 1/2 cats, 3in cat-back exhaust and 2400 converter. It ran 13.95@100mph.
1 Post
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I got 251/318 with the setup in my sig. It's totally untunned so far and the LS1 cars that day were down 10 or so HP because of the 32 degree weather. I figure I cna tune it and on a good day hit maybe 265-270 ?
Good numbers man ! I couldn't get mine under a 14.4@95 ( 3 people in the car and bald tires)
1 Post
Car: 1989 IROC-Z
Originally posted by norcalz28
Why would you race with three people in the car? Just curious? You could prolly get your times down that way for starters. My car Ran 14.0's with just headers and a catback, 3.27's. I would like to think that making 250 ish hp would drop me more than 1/10th.
Will
Will
That's a really interesting graph. Even with the Super Ram and all the goodies, peak power still comes in at 4500-4700 RPM and rolls off like a LTR intake. The roll off is probably not as severe as the LTR setup though. The heads and cam really hold our cars back over 4800 RPM.
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
what do you trap at in the 1/4?
nvmd, 104 mph is pretty dang good for a 'tpi' setup. If you had the stock tpi you would run mid 13s but have some killer 1/8th mile times
What do you you cross the 1/4 at as far as rpm goes?
Car: ws6
Engine: ls1
Transmission: m6
Hes got a Lingenfelter Super Ram intake. TPI will not trap 104 with a stock cam. If he kept his TPI set up he would probably run close to the same times as me.
1 Post
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
I would like to see a decent cam specifically for that intake and see exactly where the heads limit you at.
Car: 89 Formula 350
yeah, I know the cam is killing me.... I'm planning on installing an LPE219 cam with Brodix 200IK heads soon!
1 Post
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
1 Post
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Originally Posted by tpivette89
an fbody TPI maybe, but not a Vette. my own 89' Vette with boltons went 104.79mph without lifting a valve cover. some of the full
bolton L98 Vettes have hit 108/109mph with stock heads/cam
pos f-body stock heads and cam.
1 Post
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
I wonder how much difference a cam change and a good tune would net you. Thatd be great if you did that with the stock heads... and find theyr limitations. OTOH theres no reason to spend the time / $ on the tune if your getting heads as well. Either way good numbers, cant wait to see those heads and a new cam numbers
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Wish I had those #'s to show before a head/cam swap.
I pulled 200/248 with headers/exhaust/intake mods.
Your lighter/delete optioned Formula, Superram, 1.6rr's and pullies gave you 50 more hp and 45 more tq. Pretty cool.
Doubt even with heads/cam I'll reach 300 at the wheels.
Car: ws6
Engine: ls1
Transmission: m6
Car: '89 GTA
Yeah I don't get it either why mine is so low in comparison.
A couple guys are saying they've gotten over 300 tq with minimal mods, but then TPI-Formula350- says he got like 290's with every bolt-on.
Either people are using different dyno's or are trying to make the "correction" to their numbers based on some forumla they heard.
Car: 89 Formula 350
That torque figure looks way off.
remember this # are at the rear wheels..... you lose approx. 20% going through the drive train. so his 248 TQ would be around 298 TQ at the flywheel. Mine would be around 350ish TQ ......
Last edited by TPI-Formula350-; 03-27-2006 at 03:12 PM. Reason: Automerged Doublepost
Car: ws6
Engine: ls1
Transmission: m6
Ive had my L98 dynoed four times. The most recent numbers were 249 rwh and 334 lb ft. I have close to full bolt ons, along with the tpi intake which has been modded to the max.
249x100/80= 311 hp
334x100/80= 417 lb ft
Here is the formula I used to determine crank power. These numbers ARE high but it gives an idea of crank power if infact the 700R4 yeilds a 20 percent loss
249x100/80= 311 hp
Car: 89 Formula 350
249x100/80= 311 hp
249x100/80= 311 hp
Maybe your long tube runners are helping in the TQ dept? I'm sure my SuperRam would like more cam to make more HP and TQ at a highwer RPM.
Car: '89 GTA
What I don't understand though, is even after the calc. 298 TQ flywheel, aren't the stock #'s around 330??
stock L98s Dyno around 190-210 HP at the rear wheels
I know the GTA is heavy and fully loaded, and I know mine was in good tune, but damn, that's a low dyno to me it seems.
Car: '89 GTA
I don't even try to guess what the corrected may be or drivetrain losses, people that do that are just trying to see a nice #.
Either way 15-20-25%, my numbers seem lower than most posted and to what is advertised for factory #'s.
Car: ws6
Engine: ls1
Transmission: m6
Car: '89 GTA
Track mph's were always 95-96. Not really high.
It drives, runs strong, tune didn't show anything out of the ordinary.
Last edited by OUTATIME GTA; 03-27-2006 at 06:40 PM. Reason: Automerged Doublepost
Car: 2004 GTO
This is what my old Formula dyno'd. Had just about every bolt on, bad plug wires and running way lean.
I think it should have dyno'd much higher RWHP. Hmmmm....
BTW, your Formula still looks damn good!
Hotrodboba400
12-10-2019 07:07 PM
