Where to buy O-Rings
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Im looking to get some new o rings for the steel line that goes between the fuel rail and the flexible lines on the car. I think this is a saginaw fitting?
Any Ideas?
Any Ideas?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i bought some when i placed an order with gm parts direct, think it was less then a dollar for like a 6 pack or something, theres 2 different sizes
Car: 91 Z28 CAMARO
Engine: 305 TPI,stock
Transmission: 700R4, 2800 stall
If you didn't throw out the old ones take'm down to the local hardware store and match them up to some new ones. Much cheaper and can buy more for less. Also no shipping and waiting.
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
Car: '88 G T/A
Thanks to everyone for the info, Ill be swinging by one of these days when im not christmas shopping to see what I can find.
Car: 91-Z28
Engine: SLOW ONE
any auto parts store should have them? I have bought several set over the years, sorry I dont know the part numbers, just make them look them up for ya, fairly common o-rings fits many efi gm vehicles. The ones I got came in ac delco packages.
Car: check
Engine: check
Transmission: check
Check these part numbers:
22516256
22514722
These should be the feed and return line O-Rings for the Saginaw fittings. GM numbers, not cheap but very inexpensive (consider a lost vehicle).
RBob.
22516256
22514722
RBob.
RedLeader289
05-28-2019 01:47 PM
gixxer92
05-18-2017 11:20 AM
