Fuel pump tests good, but still no gas?
I'm not getting any fuel pressure on my fuel rail. The pump tests good when I put 12v to terminal G. But doesn't work on its own. Any ideas? I checked for loose connections, but didn't see any.
The fuse is good. I changed one of the relays, I thought it was the fuel pump, but could be wrong. The fuel regulator is an afpr, and has been on the fuel rail for a while with no problems, when I test the pump it pumps pressure to the rail. I haven't touched the filter yet though.
AkDrifted
08-17-2015 07:45 PM
