14.08 1/4 mile
Old 12-18-2005 | 08:36 AM
cutnsick's Avatar
Car: 88 GTA Pontiac right hand drive
Engine: 350 CI
14.08 1/4 mile
I pleased as.... Did 14.08 @ 96.89mph stock 350 with exaust, air foil, maf screen and air pump delete.
Is this good or average? Now im hooked, I want more
Old 12-18-2005 | 09:26 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Pretty damn good.
Take it it was on slicks or drag radials?
Most 350 cars should be at middish 14's or better in decent tune and street tire.
Most tend to be 95-98mph or so, so your doing good so far.
later
Jeremy
Old 12-18-2005 | 11:13 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
For the mods you have that is real good.
Old 12-18-2005 | 02:00 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
My car bone stock with only a flowmaster did 14.95 on worn, dry rotted tires. But mine is a GTA and have about 100 lbs of stereo in it.
Old 12-18-2005 | 10:16 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
As the spider said on Charlotte's Web "That's some pig."
14 flat is.. average for an L98 on slick, if thats on a street tire, very impressive.
Old 12-19-2005 | 06:55 AM
cutnsick's Avatar
Engine: 350 CI
Yes they are street tyres with about 2000miles on them, I drove 120mile to the track, ran the car then drove home.
Old 12-19-2005 | 07:01 AM
cutnsick's Avatar
Engine: 350 CI
O and I havent tuned the car for 5 or so years, did however take out my subs and amps..... Dont know wether i should try for a 13 or just rip straight into the motor. next event is 3 feb i was thinking throttle body bypass might do it as i was running the car hot to try to get more consistant........ DYO drag racing.
Old 12-19-2005 | 04:16 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Thats awesome. 88 Iroc L98's usually run 14.5-14.8 stock good job
Old 12-19-2005 | 07:19 PM
You have a VERY stout car to start with. I would say wait on ripping apart the motor. See how far you can go on a hogged out TPI with a Stall and bolt ons
Old 12-19-2005 | 07:33 PM
Shagwell's Avatar
Car: projects.......
good numbers. When you say exhaust, you saying headers or just cat-back? if no headers, then you know what to do next...
Old 12-20-2005 | 05:19 AM
cutnsick's Avatar
Engine: 350 CI
I have Flowtech headers with a custom 3" stainless system with a high flow cat.
Old 12-20-2005 | 07:39 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
my 87 L98 GTA with about the same mods as yours (even the 88 belt setup) ran a 14.97 - so I think you've got one heck of a factory freak there.
Old 12-20-2005 | 01:57 PM
Car: ws6
Engine: ls1
Transmission: m6
If you had all the mods I do youd be running 12.9-13.0.
Damn those factory freaks!
Old 12-20-2005 | 07:00 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
What should a completely stock internal 87 TPI run with an air foil, 1 5/8in headers, 2 1/2in exhaust with a glass pack w/out cats, Walbro 255 lph pump and MSD 6A, and Air pump delete run? Because I hit a 14.0 on baldish street tires and the motor has over 140,000 miles on it. Was that with the stock 2.73 or 2.77 gears? Because my car used to run a slower time at higher mph than it does now with 3.27. In any regard that's a decent time, keep on modding it's addictive and fun!
Old 12-20-2005 | 07:01 PM
Wow i suck you said 14.08 not 14.80 BIG difference, yeah that time rocks man that's about where I am with more mods than you!
Old 12-20-2005 | 07:25 PM
Shagwell's Avatar
- i just saw that your car is a aussie car. - should be 9-bolt w/ 3.27 gears factory. I had the same, but w/ the TPI the best i saw stock(ish) was 14.72...being right hand drive and all, there could be other differneces/perks, like non-US emmissions...
Old 12-21-2005 | 08:31 AM
cutnsick's Avatar
Engine: 350 CI
Only difference is i ripped off the air pump. Those things suck, Also I had to squash one of the header tubes to clear the steering colomb. We have very good air here and the tyres barely spun even when i lanched as hard as possible 1.96 60ft.
Also there is more in my trans as the 2nd gear bands are dodgy after doing burnouts.
I just hope I can get it into the 12s easily, I have bought larger runner tubes, comp cam with 218,224 deg and 495/503 lift, afpr and a shift kit but are yet to fit any as have to make a desision on new vs recon heads. Any head advice would be welcome
Old 12-21-2005 | 08:33 AM
cutnsick's Avatar
Engine: 350 CI
o yeah and i have 3.27 gears i think. Havent had a look under there for some time. also 85000 miles.
Old 12-21-2005 | 01:42 PM
Car: ws6
Engine: ls1
Transmission: m6
I though the 88's had 2.77's if you didnt get the g92 package?
Old 12-21-2005 | 09:16 PM
Mikos_89's Avatar
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
No. For the '88MY, all GTA's became fully contented models for the most part. If it had B2L/L98 which was standard equipment, then it would've came with RPO (G92) and the 3.27 rear gears.
12's won't be easy with reconditioned stock heads unless you use nitrous. You could go with the CNC'd ported L98's from Lingenfelter. Those are good, but that's major $$$ though. AFR 195's are another good option for your 350. Again, they're pricey like the Lingenfelters. Pro-topline is a choice you might consider. Those heads are not too expensive and there are alot of people running them on this site with good results.
The GM Vortec's are pretty cheap, compared to the others, and can give you great results. However, you'll have to run the Scoggin's Dickey intake base for them to work properly though.
Old 12-21-2005 | 09:35 PM
Car: ws6
Engine: ls1
Transmission: m6
oh ya, forgot it was a bird.
Old 12-22-2005 | 04:20 AM
cutnsick's Avatar
Engine: 350 CI
Thanks once again for all your help guys and galls. Ill post again when ive changed something and run the track again
Old 12-24-2005 | 03:36 PM
Apparently we all suck, there's a guy in a bolt on GTA claiming to have hit a 13.15
Old 12-24-2005 | 08:09 PM
Car: ws6
Engine: ls1
Transmission: m6
[QUOTE]Originally posted by 1991CamaroRslow
Apparently we all suck, there's a guy in a bolt on GTA claiming to have hit a 13.15 [/QUOTE
Is he running tpi or an aftermarket intake?
Old 12-25-2005 | 02:41 AM
https://www.thirdgen.org/techbb2/sho...ght=gta+13+ls1
GeneralIesrussi
Carburetors
06-20-2024 07:21 PM
83 Crossfire TA
01-03-2016 01:26 PM
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
86CamaroDan
09-29-2015 10:08 PM
Stryker412
09-07-2015 09:11 AM
Quick Reply: 14.08 1/4 mile
