lets see your TPI intakes
Old 11-29-2005, 12:31 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
I need some pictures of your intakes. i think i have the most restrictive one here. i really should make or get a better one.
Old 11-29-2005, 10:14 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
h
Old 11-29-2005, 10:24 AM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
Old 11-29-2005, 10:26 AM
BlackMagic's Avatar
Car: 1986 Firebird
Xlr8torZ28's Avatar
Engine: LB9 & L98
here is something that will help you
http://www.gmtips.com/3rd-degree/dox...-port/port.htm
Old 11-29-2005, 10:43 AM
jamon8's Avatar
Engine: 350 tpi
in that diagram that says runners. I just cut those out and grinded them back as far as I could. do this at your own risk.
Old 11-29-2005, 02:12 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
I think by intake you mean the intake tract?
well heres mine:
Old 11-29-2005, 03:24 PM
Cali Z's Avatar
85 TPI --- A few things have sinced changed but this pic shows the tpi well.
Old 11-29-2005, 06:33 PM
Shagwell's Avatar
Car: projects.......
I think he's talking about the air filter ducting. Not the intake. If so, yes his is one of the most restrictive. - what evr you do, don't use metal unless it's well painted/powder coated. The heat sink of polished is horrid...
Old 11-29-2005, 08:22 PM
ator's Avatar
Car: 92 Firebird Formula
Transmission: 700 R4, 3.73 rear
Old 11-30-2005, 01:15 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I got a new powermaster 140 amp alt on there now aswell ...so it's a lil less ugly
Old 12-06-2005, 06:40 PM
TGO - 10 Year Member
Rosco the Iroc's Avatar
Car: '89 IROC, '14 LTZ Burb, '18 H6 Outb
Engine: 355 TPI /w Vortec
Axle/Gears: 9 bolt 3.27
Ready for it's first start.
Old 12-07-2005, 06:32 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
SLP runners.
Old 12-07-2005, 04:37 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Old 12-07-2005, 07:21 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Geese man , mine and your cars are VERY close in every way I made 251 rwhp and 318 rwtq( 083 heads and ZZ4 cam) . With the same intake you have ( I am above your origonal post) ...same goodyear blue hoses and we had the same idea of buffing the fins and podercoating the intake.
Old 12-08-2005, 11:16 PM
5.7tpiroc's Avatar
Car: 89 Iroc
Engine: 5.7tpi
Axle/Gears: 9 bolt posi w/ 2.77s
heres mine before i began the process of putting on my converted lt1 intake.
Old 12-09-2005, 08:34 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
https://www.thirdgen.org/techbb2/att...postid=2472612
Old 12-09-2005, 04:55 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Old 12-09-2005, 05:43 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Hey rosco, did you use the SDPC vortec manifold w/ your setup?
Old 12-10-2005, 12:15 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
Old 12-12-2005, 11:30 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Probly seen this before but...
http://www.wideopenwest.com/~Johnand...eWeb/photo.htm
Old 12-12-2005, 12:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
well u said tpi intakes so heres mine-- ACCEL superram base
in process of port job
Old 12-18-2005, 11:16 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Here'a pic I found just after i completed the tpi swap. Although it's not going to look that way after x-mas. I am looking to get a super ram set up come Jan/Feb.
Old 12-19-2005, 12:12 AM
polishdevil's Avatar
Car: 88 GTA
what are you useing to port the intake?
Old 12-19-2005, 01:05 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Here is mine...
Old 01-03-2006, 01:32 PM
Sorry for the late reply, but yes I did.
Old 01-03-2006, 03:05 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Here's mine:
Old 01-03-2006, 05:36 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Here's Mine
Old 01-03-2006, 06:22 PM
HD4mula's Avatar
Old 01-03-2006, 07:42 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Old 01-06-2006, 07:52 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
My Intake = Port Job
Old 01-06-2006, 08:16 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Hand polished before i painted the runners black.
Old 01-06-2006, 08:39 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I have a little push behind mine
Old 01-07-2006, 10:34 PM
SC2camaro's Avatar
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
did opening up those 2 ports into one make a diffrence?
also do you have the big runners?
Old 01-07-2006, 11:03 PM
jamon8's Avatar
Engine: 350 tpi
I did the same thing and it just seemed right to me because the walls are restrictive.
I have the stock runners w/305 setup.
I am not telling you to do it. I am only saying it did not disrupt my idle and because I did alot of mods with it I could not tell you about the performance enhancement
Old 01-08-2006, 12:22 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Most people would say that it benefits topend power, but on my LB9 i could break the tires loose from a dead stop after i did that, where as i couldnt break them loose before.
When i cut down the EGR walls behind the throttle body it did help out on the topend.
LB9 + 700R4 + 2:73 Rear + New Tires =Great Traction
Old 01-08-2006, 08:15 AM
SC2camaro's Avatar
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
kewl
well a L98 + 700r4+ 2.73 rear with new tires i still have no problem lighting the tires up from a stop.
I would like to keep the TPI look but i want to make some decent power with it . My gn puts down 350 @ the wheels on pump gas a low boost. i ould like to have the maro get close to 300 @ the wheels.
i'm going to the track today and run it 1/8 mile i'm thinking 10's here i come lol
Old 01-08-2006, 10:19 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
5.7 0.040 block cleaned up heads small cam TPI airfoil k/n air filters catback exhaust AFPR svo injectors custom prom trick-shift shift kit. march underdrive pullies Alt/Crank 2.73 G80
That and 45 more cubes will make a difference compared to a stock 305.
Old 01-10-2006, 11:14 AM
roosterjuicer's Avatar
Car: GMC Sierra 1500HD, 92 z28 25aniv
Engine: 6.5td/305
Transmission: 5-sp
Old 01-12-2006, 02:23 PM
jack_sparrow's Avatar
Car: 1985 Camaro
Engine: 350 bored 40 over
Transmission: 700-R4 Race prepped
Here's a few more...
Brett
Car: 1985 Camaro
Brett
Old 01-12-2006, 06:03 PM
  #42
Engine: 6.5td/305
Transmission: 5-sp
i think it would be interesting to see how much of a difference all these different intake/runner combo's make
Old 01-13-2006, 12:51 AM
  #43
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
Ours look pretty similar!
I haven't decided if I'll keep this air ducting or not. My truck doesn't need more than 4500 rpm anyways, so I'll probally leave it, and slap a paper filter on the end. Looks very nice, and it's open is directly infront of a big 3 - 4" hole in my rad where my factory air cleaner used to hook up to get fresh air from the grill
Old 01-14-2006, 12:38 AM
  #44
Julie Bergman's Avatar
Car: 91 Formula WS6
Transmission: five speed
Luke, are these the Billet Specialties valve covers?
Old 01-14-2006, 03:35 PM
  #45
MdFormula350's Avatar
Cant get more restrictive than stock
Old 01-14-2006, 11:53 PM
  #46
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
heres an old pic, empty engine bay right now i will have some more higher quality cleaner bay pics soon
Old 01-15-2006, 12:15 AM
  #47
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
heres mine, old pic but I will update soon, engine bay is empty right now finally, will have some higher quality cleaner engine bay pics soon
Old 01-15-2006, 02:58 AM
  #48
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
Just finished build tonight.......
Old 01-15-2006, 02:08 PM
  #49
b_the_j's Avatar
Car: 92 RS
here is mine
Old 02-05-2006, 01:09 PM
  #50
Realmac4's Avatar
Car: 1991 Z-28/ '94 Impala SS
Engine: 355 TPI/ 350 LT-1
Transmission: T-56 in both
Axle/Gears: 3.73 / 4.56
One of mine, AS&M runners, ported plenum
Quick Reply: lets see your TPI intakes
