Best Gears For TPI
Car: ws6
Engine: ls1
Transmission: m6
Best Gears For TPI
Is it true that the best gears for a stock TPI L98 are 3.27's, and 3.42's for a TPI that has mild bolt ons such as Exhaust/Ported Intake and Runners. Also I hear that 3.73's are bad for the TPI's powerband, and 4.11's are way overkill. I know this has been posted alot but for some reason I cannot understand the TPI's powerband. I have seen 2.77 L98's run quicker than 3.27 L98's. I don't get it.
Also do these rpm's at 60 mph look correct for the gears on an L98? [Put the car away for the winter so I cant go check]
2.77's=1650 at 60mph
3.27's=1850 at 60 mph
3.42's=2000 at 60 mph
3.73's=?
4.11's=?
Thanks.................
3.73's=?
4.11's=?
Car: 85 Z28
Engine: ZZ-3,Mini-Ram, Holley EFI
Transmission: 700-R4
Axle/Gears: Hawks 8.8
TPI Gears
My 85 z has a 700 r4 & 3.73 gears.
60 mph is 2000 rpm with converter locked.
Car: 1991 TRANS AM GTA
Engine: 5.7L TPI
Axle/Gears: 3.23 Posi
I have run in the past with 3.73's(and plan on goin back now, I miis'em), but the car ran very well with them. With 3.73's you can rocket off of the corners, its like a sling shot.
a L98 with aftermarket intake/runners/injectors/chip in a firebird i saw at the track with stock converter was hittin overdrive 4th gear with 3.73 gears.
i'd say 3.27's is a great match but the 700r4 makes it kinda tough. the big gap between 1 and 2nd gear really hurts. 3.42's would be better while in second and third with the ratios of the 700r4 trans. but the big 3.06 first gear would make 1st gear pretty quick with 3.42's and its already kinda quick with the 3.27's.
with a th350, i'd say 3.42's would be a nice choice. but 3.23's or 3.27's would equally perform.
the 700r4, 3.27's seems to run fine. although i bet u can pick up precious tenths by using 3.42's cuz it will lessen that 1-2 jump and keep the rpms up for that second gear.
i'd recommend a 2400-2800rpm stall for TPI... and fully modded TPI's can go as high as 3000
Car: ws6
Engine: ls1
Transmission: m6
I bet those 3.27's are better on the highway than the 3.42's. In 1/4 time there is proably not much of a difference.
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
My formula originally had 2:73 gears, at 80 mph the tach was dead on 2000 in od.
I upgraded to 3:42 and it was about 70 mph at 2000 rpm ( The kick in the pants when I stepped on the gas was worth it, tho)
This was on a 355 L98 with just a 3" flowmaster exhaust.
1 Post
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
3.73's here too . Just can;t get over them first two gears . Feals like your driveing the fastest thing in the world ....but I have a 5 speed
Car: ws6
Engine: ls1
Transmission: m6
Orr89RocZ, How much easier is it to spin your tires with the new 3.27's than it was with the 2.77's? Maybe thats why some 2.77 cars beat the 3.27 L98's.
Car: projects.......
many times, you'll spinn easier with a steeper gear. If you have the power, your motor will be bringing the tire speed up quicker w/ higher gears(numerically lower). it all depends on your combination and power band. I know of cars that ran faster w/ 3.00's than 3.73's. But a 383 TPI(LTR set-up) w/ good heads and such makes a LOT more torque than a 355 w/ a HSR, so it's powe band was better suited for the 3.00's...
its all about the combination...
1 Post
Car: 1989 IROC-Z
BAM ! exactly! I have the 3.73's like I said above ...but they sure aren't optimal for the track . Just wicked lil streeet rocket.
BTW I turn 2000 rpm at 60 mph ....but with a 5 speed Thats good enough for me
Car: 89 Formula
Engine: 5.7 TPI
Originally posted by CC89Formula
a 700R4 shouldnt shift into OD at WOT....
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My 700R4 in my 88 Formula would shift to OD at WOT.
I also gained 3 mph and dropped half a second in the 1/4 mile going from 3.23 to 3.73's with the bone stock TPI.
here is a vid showing the car going to OD at WOT,
http://www.transamws6.com/video/130mph.wmv
I changed the rear end of my car from 2.73 to a 3.23, I have not changed the speedo gears yet though, my car tops out at ~95mph, yet the speedo says 115. When i change the speedo gears, will my car still top out at 95 or will it go to 115?
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Nice Music. , was the speedo corrected when that pull to 130 was made?
but i chirp second gear on shifts now alot more than before with the 2.77's
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
To get better gas milage with 3.73's, go with a RS T-5 over the IROC T-5.
5th gear .63 for RS
5th gear .73 for IROC
5th gear .59 for RS with G-Force package
5th gear .68 for IROC with G-Force package
5th gear .63 for RS
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I hated my 373 with my auto and tpi. I ran out of rps by then end of the track. I would hit 6000 in third and you cant shift into fourth cause it wont go.
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Go wit the 3.27's. Great Gas mileage with off the line performance. The 700s first steep gear is already the "off the line multiplier" Just lower ur tire pressure to about 28 and have fun.
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
tranny gearing
has anyone on here used a 2004r trans instead of the 700r4 due to the beatter gearing from 1-2 ?
MY gn has a 2004r and it just rocks with a 3.42 gear and with a 26 inch tall tire it turn about 2300 @ 70 mph
my 91 z has a 2.73 posi in it and it feels great in fisrt gear but when it shifts to second gear you will break you nose on the steering wheel it lays over so hard.
i was thinking of a 3.23-3.27 gear for it also since my old 85 5.0L TPI was geared that and it was peppy.
if the 1-2 gear was better, like a 3.06 first drop to 1.9x or even a 2.0x second gear, combined with 3.27's or 3.42's, a tpi car would really shine.
i believe that drop costs precious time. you have alot to gain with abit better gearing. my 60's are pretty good but the 330 and 1/8 could be better i think. some other cars and trucks with similar power but better gearing in th350 trannys and sticks run similar 60 foots but run quicker ET's in the first 1/8 which leads to better ET's in teh 1/4 while trappin less than i do. my ET's could be alot deeper into the 13s i think with a better 2nd gear ratio.
think about it.... 3.27s puts me at 30mph in first, and carries 2nd to about 60 shifting at near 5K rpms. that doesnt really seem bad but it is cuz i have such a short power band with TPI. and it does take awhile to go thru second. 2nd gear rolls at 30-35mph are slow.
third gear is the gear that lasts for ever, going from 60 to 100mph. i trap the 1/8 at 80mph.. so i'm middle 3rd gear crossing the 1/8 mile and stay that way all the way out. 3rd gear will ride out to about 115mph or close to that. thats as high as ive been in third now
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
gears
my old 88 LO3 had 2.73 gears with 26 in tall tires and in the 1/8 mile after you crossed the timing lights and lift up on the throttle to start shutting down the car would shift into 3rd gear.
I really think that a 2004r trans in a f-body with a 3.27-3.42 is all it needs.
the biggest problem is that redheaded stepchild trans 700r4 with is go to hell gearing.
that trans gearing makes it feel like it has got big ***** til it shifts to second then it dies out.
Car: ws6
Engine: ls1
Transmission: m6
Originally posted by 92zcamaroperson
Yeah im not sure what gears I have but man i can spin so easily. Which kinda sucks because its hard to take off quickly.
...it all depends on the combination/intended use. For all out drag racing, you want to be turning your peak hp rpm as you go throught the traps, 1:1 in the tranny(3rd in a 700). But other combinations of power(peak and curve)/ intended RPM/ weight/trans gearing/intended use, make or brake rear gear selection.
Car: 1989 Formula Ws6
Engine: 305 tpi
Transmission: 5speed
at 80 mph my 89 5.0 in 5th is around 3500rpms, can some one give me a idea on what kinda gears i got, its in storage too
I forgot to add that I have my 700R4 governor set up to shift at 6000 rpm in 1st because of the big drop to 2nd. The 2-3 shift is at 5600rpm. I will have to look at my datalog again but the 1-2 shift is around 35mph and the 2-3 shift is around 70+mph. Again this is with 3.70 gears.
if you go to the home page on here and click on the equations, you'll find all the info you need about rpm vs speed for what gearing... - If you want the best of the best(automatic), w/ overdrive, look into a 4l80e/4l80 w/ manual valvebody...turbo 400 w/ overdrive...
ps. trans gearing for 700r is 1.1 in 3rd .70 in 4th. - For stick cars, you'll have to check in the tech data, as there are a couple options...
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
4l80e/turbo 400
I don't think any of these guys could justify going with a 4l80e trans or a turbo 400. Due to the fact of the power there making. a 4L80E is power hogging unit. yes i know it can live with some high power. but these guys are not making that kinda power.
I personally think a 2004r will be the best trans of choice out there if your gonna make a trans change. it has be proven that a 2004r with good internals will live well into the low 10's.
my buick is making 350RWHP and 440RWTQ and that 2004r all it has in it internally when i rebuilt it is. a harden stator 10 vane pump .521 boost valve no yo yo shift kit kevlar band with heavy duty anchor pin and red alto clutches and steels. it might dided tomorrow but it has been beast to death for 1.5 yrs and several track passes with slicks.
i have listed below is the transmission gearing for a 200-4r. notice how there is not the major change from 1-2 in the 200-4r like the 700-r4
the diffrence from 1-2 in a 200-4r is 1.173
the diffrence from 1-2 in a 700-4r is 1.434
Transmission
Model
Rear Wheel Drive:
First Second Third Fourth Reverse
THM 180C (3L30) 2.400 1.479 1.000 ----- 2.000r
4L30-E 2.400 1.479 1.000 0.723 2.000r
4L30-E Optional 2.860 1 .620 1.000 0 .723 2.000r
THM 200-4R 2.741 1.568 1.000 0.674 2.067r
THM 700-R4 (4L60) 3.059 1.625 1.000 0.696 2.294r
4L60-E 3.059 1.625 1.000 0.696 2.294r
THM 400 (3L80) 2.482 1.482 1.000 ----- 2.077r
4L80-E 2.482 1.482 1.000 0.750 2.077r
TH350 2.52 1.52 1.00 ------ NA
i got my info from www.gnttype.org under the tech info
also the 200-4r has a steeper 4th gear. so u can use a lower gear in the rear axle. the gn's use a 3.42 from the factory.
but i been running my street tires on 25-27psi on the street with LCA's/brackets, panhard bar, adjustable shocks and eibach springs and i still cant hook all that well. still gotta walk it out the hole abit. first gear is violent LOL
ambainb
04-25-2016 09:21 PM
Iroc8t8
08-26-2015 08:14 AM
Sanjay
08-12-2015 03:41 PM
