Trying to add a fuel pressure gauge.. what size is the nozzle?
Im trying to add an external Fuel Pres. gauge to the stock fuel rails on an 87 350 TPI. I need to know what size fitments I need for the plumbing. I have 1/8 inch fitment that just doesnt seem to cut it. Anyone know the size I should be using (what are the dimensions on the port on the fuel rails?)
help
hey, i know this thread is pretty old but anyone know where i can get one of those fittings? im goin nuts tryin to find somethin that will hook up to the pressure port. i assume you guys are indeed talkin about the shraeder valve. if its a common fitting, wanna just tell me what to ask the hardware guys in a language theyll understand?
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Summit racing or jegs has a great selection of automotive plumbing, tell them you need an -AN 4 fitting, and hose to match it for your gauge. The fittings themselves cost around $5-6. Hose $14 at 3ft
toronto formula
11-10-2015 06:17 AM
92camaroJoe
08-13-2015 06:07 AM
