350 with 19# injectors?
Old 11-16-2005 | 03:12 PM
dbs90irocz's Avatar
Car: 90 Iroc-Z Vert
Engine: L98/5.7L TPI
Is running 19# injectors on a 350 going to cause any problems? I have the fuel pressure set to 32 PSI and I'd like purchase new 21# or 24# accel injectors, but I've got to wait awhile!
Old 11-16-2005 | 04:10 PM
FrankenT/A's Avatar
Car: Trans Am
Check out my thread........right under yours. I asked the same thing. Basically, get the correct injectors.
https://www.thirdgen.org/techbb2/sho...hreadid=331350
Old 11-16-2005 | 04:12 PM
brutalform's Avatar
No problem. just bump up the FP.
Old 11-16-2005 | 04:18 PM
dbs90irocz's Avatar
Car: 90 Iroc-Z Vert
I've bumped the FP to 32 PSI is that enough or should I go higher? It seems to run real nice, but I haven't gotten it out for a test run yet! Dam Rain! Anyway It's a completey stock engine, but I've got some add-ons! Exhaust, K&N's, Headers, Hi flow Cat, Hypertech chip, etc.....
Old 11-16-2005 | 05:39 PM
brutalform's Avatar
3 bar is 43.5 PSI, and that is where the factory injectors are rated at. I would start there, and move up in pressure if need be. At 43.5 the #19s will flow 19lb hr.
Old 11-17-2005 | 01:56 AM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
I'd be concerned something was wrong with my gauge... Technically, the engine shouldn't run very well with 3-bar 19 lb/hr injectors running at 32 psi!
However, if you bump up the fuel pressure they should be fine. Doing some quick ratio comparison math, you should run your fuel pressure at 50 PSI to get 22 lbs/hr out of a set of 3-bar 19 lb/hr injectors
Old 11-17-2005 | 04:03 PM
KenV's Avatar
Car: A few
Engine: All Eights
Transmission: All kinds
FWIW I had a stock 145K L98 running Ford 19s. With 48psi (vac off) and no tuning, she pulled great (enough to finally finish off the 700R4) and hit just under 28mpg on a trip to Tahoe. The rest of the mods consist of the Holley AFPR and a catback. 3.23s in the 10bolt. HTH
K
Old 11-17-2005 | 04:35 PM
brutalform's Avatar
I reused my 19s from my old 305, and used them on my old 355, and ran 13.00s. If I went up past 48 on the FP, the car ran real rich, where it smoked out the tailpipe.
Old 11-17-2005 | 04:37 PM
FrankenT/A's Avatar
Car: Trans Am
So you guys didn't need to repro the computer? But you do need an AFPR correct?
If so than I am worry free.
Old 11-17-2005 | 04:44 PM
brutalform's Avatar
Back when I had my old 355, I did not even think I could reprogram my own proms. I had an ASM mail order prom, but even so, with an increase in FP, the 19s supplied plenty of fuel for my 355.
Yes, you will need an AFPR, and a FP gauge.
Old 11-17-2005 | 08:32 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
22# injectors will barely support 300 HP at 50 psi and an 80% duty cycle. Check out this chart. You will have to scroll down and insert the data in the blocks to get the size of injectors needed. http://www.rceng.com/technical.htm
A BSFC of around .50 would be good for a standard motor. A built street motor with good heads can use a BSFC of .45. A race motor can use a BSFC of .40.
Old 11-18-2005 | 09:53 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
It's just like I was saying in the other thread. If you are bump up the psi on a 19# injector, you will make it go static and will run lean. A static injector is just open, and will not be able to flow any more fuel than at wide open.
As I stated, the 19# injector will work in the lower RPM band, but when you start revving it up into the high, you will send the injector into static. Sometimes they don't come out either, meaning wall wash, new injectors, and hopefully nothing else worse.
I'm not saying that you're car is going to fault no matter what, but it will not be making complete power and could be wearing itself down faster if not properly setup.
Old 11-18-2005 | 11:58 AM
Car: 1989 GTA
Engine: 369 TPI
Also it is not good to go above the 80% duty cycle as the injectors "may" become erratic in operation above that range. The above post is dead on.
Old 11-18-2005 | 06:04 PM
IceBlue91z28's Avatar
Car: 1991 Camaro Z28
Transmission: Built 700r4
it is a problem. I had a 350 put in and i hadd the 19lb injectors from my 35. it runs real lean no matter what u set the fuel pressure at and that means the engine runs hot and thats no good. get slp 24lb injectors $100 a set
Old 11-18-2005 | 09:27 PM
Vader's Avatar
It can be done, and can be made to run, but the proper method is to install the larger injectors - THEN program.
MustangBeater20
10-29-2022 10:20 PM
bamaboy0323
09-03-2015 07:07 AM
xxx3man`
08-28-2015 03:21 PM
Keith5
08-27-2015 05:37 PM
Eric-86sc
08-24-2015 10:01 PM
